Old 06-01-08, 05:58 PM   #1
leemole
Thumbs down brakes stuck on ??
my bike has become harder to push around over the past few days and i think one of the brakes is stuck on a little but still perfectly ridable. Is this a simple problem to fix ?
Old 06-01-08, 06:14 PM   #2
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: brakes stuck on ??
mine aswell, I think the callipers are all gunked up and need a clean thats why they're not releasing making it harder to push, but only one of mine is doing it
05 DRZ400E
RIP hovis
Old 06-01-08, 07:15 PM   #3
Bear
Sounds like you have a caliper binding. Do a search with that as the title and I'm sure you'll find stuff. As far as I know it's pretty much a case of stripping and lubing the pistons, but do a search first as I'm not 100%.
Old 06-01-08, 07:26 PM   #4
dirtydog
Knob faced knobster
dirtydog's Avatar
you might be able to get away with just giving them a clean, take the calipers off pump the pistons out a little bit and clean them with some brake cleaner then smear some red rubber grease round the pistons and push them back in
If your not lucky you may need to replace the seals
2011 Speed Triple 1050
Old 06-01-08, 07:29 PM   #5
petevtwin650
If it's a curvy I'd check out the rear caliper first. Just detach and support it, then try pushing the bike.
Stuck in an Elevator Warthog Idle Banter 9 21-04-08 11:19 PM
stuck in gear thinman SV Talk, Tuning & Tweaking 4 25-03-08 02:03 PM
Bolts on Reg/Rec stuck Colby SV Talk, Tuning & Tweaking 13 04-02-08 04:42 PM
something stuck? Stingo Idle Banter 2 30-05-06 04:32 PM
