Hullo,
Looking at their catalogue (for my front brakes), it looks like I can either get the two full length hoses from the master cylinder to the calipers, or also the two hoses plus the link pipe from the lever assembly/reservoir to the master cylinder. It kind of feels like a daft question, but is it strictly necessary to get the second option, or can I just go with the main hoses to the calipers? Will it really make much of a difference without the link hose? Cheersy the d |
I went with the first option, no real reasoning behind it - just my personal preference.
'52 Curvy S | So good.....it made me want to trump! If at first you don't succeed - use more gaffa tape. |
Are you sure the two-pipe versus three-pipe options aren't simply 2-line front and 2-line front+back? Just a thought.
Ignoring their shocking customer service for moment, M&P 'budget' brake lines for the front cost me £20 + P&P and are made by and despatched straight from Goodridge! |
I think three lines, as its a road set-up and not a race setup?
I got 3 lines when i ordered a goodridge brake line set Matt |
Chazzy- it does seem to be the for the front and about £30 more (hence the ask!!!)
Matt- I'm confused! Why would less steel hose be a race set up? Surely if there's a rubber hose in the chain it will soften the response a little (enough to notice?), rather than all the pipes being braided? |
For the SV as after market its recommended by HEL and Goodridge to have 2F + 1R. A dedicated line to each front caliper apose to a split shared one increases the brake force even more!!
#7 | |
I suppose that was my personal reasoning behind the 2 lines. ![]()
Twin pipe set up for me too. Allows you to get rid of that horrible pipe splitter fitted to the lower yoke.
#9 |
Both setups are fine, neither will give "more force" as this is determined by the calipers and master cylinder. The 2 line setup is cheaper as there's only 2 lines and 4 banjos. The 3 line setup apes the standard setup and gives a braided line to the splitter on the bottom yoke, then 2 lines down, for this you need an extra braided line, and an extra 2 banjos so it costs more.
Some people prefer the 3 line setup because it looks neater, the 2 long lines can also IMO be a little trickier to bleed if air gets trapped at the top in the new double banjo from the master cylinder, but it's no major biggie. You can also have a 3rd type of 2 line setup: A single long line down to one caliper, then a short link line over the mudguard to the 2nd caliper. Again this is a nice neat way to do it, but less common, and thus tends to cost more than the 2 long line setup. In real terms, once bled there will be no difference that you can feel between any of the above setups, the amount of flex in a braided line is tiny, so pick the one that you like the look of and suits your wallet. ![]()
#10 |
OK- gotcher, I think. So- I guess, if I'm switching from using the splitter to both lines out of the master cylinder, the HEL kit will contain all I need for connecting to the m.c?
Hel Brake Line Length | Biker_Billy | SV Talk, Tuning & Tweaking | 7 | 27-03-08 10:33 PM |
HEL Braided brake line help | DoubleD | SV Talk, Tuning & Tweaking | 9 | 07-03-08 06:56 PM |
Brake Line Clips, really need them. | DoubleD | Stuff Wanted | 14 | 05-03-08 05:52 AM |
Brake Line length | Torn-Thorax | SV Talk, Tuning & Tweaking | 2 | 10-03-07 02:26 PM |
Brake line bracket - anyone got one or where to get one? | rich_r | Bikes - Talk & Issues | 5 | 01-11-06 09:11 AM |
