Old 17-01-08, 12:40 AM   #1
twonky
Default front wheel
Does anyone know if a front wheel off a carbed sv 650 fit an injected model?I have been told if i change the bearings and wheel spacer it willl fit.
Old 17-01-08, 05:04 AM   #2
zadar
Default Re: front wheel
you dont need to change bearings,axles are same size.
however you need new spacer on right side and curvy axle to use it.speedo is same on both.
Old 17-01-08, 05:31 PM   #3
jambo
jambo's Avatar
I can't remember if there's an issue with the discs. I know the 99-02 front discs are dished, and the 2003+ discs are not, but I'm not sure if the hubs are the same diameter etc...
Old 17-01-08, 05:43 PM   #4
Stu
Trinity
Stu's Avatar
Northwind said the bearings are different IIRC.
Why not sell your curvy one to Big Ape & buy my pointy one?
Jobs a good'un!
Old 17-01-08, 06:27 PM   #5
zadar
bearing ID is same,spacing between rotors is same even tough curvy ones are dished.
curvy is narrower at hub and reason you need yo use curvy axle.pointy has axle that has step on it instead spacer.
Twin Works Factory sells spacer kit for this application but they are in USA.
SV650 Front Wheel - Do any other Suzuki models use the same front wheel? williamturner1 SV Talk, Tuning & Tweaking 11 30-05-10 02:31 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
Front wheel K5 phil24_7 Stuff Wanted 0 23-02-07 10:28 PM
k3 front wheel davemaz Stuff Wanted 1 04-01-06 07:12 PM
front wheel maintenance ?? need to prop up front wheel etc valleyboy SV Talk, Tuning & Tweaking 2 26-08-05 07:50 PM
