Ancillaries Post your own reviews, opinions and experiences on various other bits and bobs, such as rearsets, oil, engine bits.
Old 18-01-08, 02:03 PM   #1
Chipstix
Default sockets and leads, modifiying my Garmin!
Hi All,
I am trying to source components to enable me to fit an audio socket onto my SatNav unit.
I would like to fit either a 2.5mm of 3.5mm socket (drill hole in plastic housing and fit on. Like this....[thats not my unit, or hand by the way!!!]
The output of this needs to go into a 4-pole stereo 3.5mm socket on my autocom unit.
I am looking for:
a) suitable socket to fit to SatNav unit
b) suitable lead
The socket needs to be switched, so that when a 3.5mm jack is inserted, the sound is cut from the SatNav internal speaker. Any advice, have had a good look on Maplin, ebay, rs but not found quite the right stuff......
Thanks in advance, Chris
Old 18-01-08, 02:23 PM   #2
tigersaw
tigersaw's Avatar
Default Re: sockets and leads, modifiying my Garmin!
why have you not found the right stuff on maplin? Do you need waterproof, or slim design or what?maplin HF78K will do the job you describe for instance
Old 18-01-08, 02:37 PM   #3
Chipstix
Had seen that socket. That will do the job fine but then I need a way of getting a 2.5mm mono output into a 3.5mm stereo input. Haven't found a 2.5mm mono to 3.5mm stereo lead.
Any ideas......?
Old 18-01-08, 03:24 PM   #4
tigersaw
tigersaw's Avatar
plugs, screened cable, soldering iron?
Old 18-01-08, 04:50 PM   #5
aarond
what i did was connect a cable running out of the unit will try and find a pic so could use http://www.maplin.co.uk/Module.aspx?...ocket&doy=18m1
And obviously just cut off the male connector or if you just want the socket
Old 18-01-08, 04:52 PM   #6
aarond
sorry this is what i mean
Curvy Engine and Swingarm Removal Tools/Sockets Demonz Stuff Wanted 11 21-07-08 03:48 PM
1/4" drive sockets embee Bikes - Talk & Issues 8 29-05-08 01:25 AM
anyone use a Garmin i3? Chipstix Bikes - Talk & Issues 9 01-05-08 08:44 AM
Garmin I3 aarond Ancillaries 10 08-05-07 03:07 PM
imperial sockets lukemillar Bikes - Talk & Issues 5 06-08-06 10:32 AM
