Old 24-01-08, 01:25 PM   #1
Drew
Default Changing Light Bulbs...
Ok, how do I change my front light bulbs on the pointy ? I have purchased some H4 bright ones but can just about tell the difference between screw drivers... Is it a simple job ? thanks Drew
Old 24-01-08, 02:31 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: Changing Light Bulbs...
PM Furry Ginger One
I told him how to do it (kind of) but hes done it more recently than me
Old 24-01-08, 02:45 PM   #3
Stig
You need a 5 pound sledge hammer.
Old 24-01-08, 02:59 PM   #4
SoulKiss
SoulKiss's Avatar
Not going to work.
A considerably heavier Range Rover wasnt any use in changing mine
Those ARE the Phillips replacement ones
Oh and BTW I wasn't trying to be awkward in referring to FGO - just I dont really remember apart from retaining clips, making sure they are the right way up and rubber boots........
Old 24-01-08, 09:45 PM   #5
Stig
You need a 50 pound sledge hammer.
Old 24-01-08, 09:45 PM   #6
Stig
and a very strong big bloke to swing it.
Old 24-01-08, 09:53 PM   #7
Stu
Trinity
Stu's Avatar
Not going to work.
You got knocked down by Devil Biccy?
Old 24-01-08, 10:15 PM   #8
FG1
Quite easy really, if not a bit fiddly til you have done one.
You might find that taking off the small cover on the fairing will help with visibility of the back of the light.
Firstly, pull off the electrical connector from the back of the bulb. Then fully take off the rubber gaiter type thingy. Next, and this is the bit where I got stuck, release the spring clip holding the bulb in. This is where removing the cover from the fairing comes in handy. Take old bulb out and put new bulb in, remembering to avoid touching the glass of the bulb.
Carry out all of the above in reverse and, if you think its needed, raise the headlight level a bit with the 8mm bolts/crosshead bolt accessed through the fairing cover which you have already removed.
I put some Halfords 50% brighter bulbs in and raised the beam a bit and the differene is amazing. My level is set so its just below the rear windows of the car in front. Possibly a tad high but works for me and I've only been flashed once.
Old 25-01-08, 10:32 AM   #9
Stu
Trinity
Stu's Avatar
There's a hole in the fairing that exactly lines up with this screw (having the side fairing off will help you see it though)
+1
Curvy R&G tail tidy with Mini-Indy's - Changing Indicator Bulbs, how? krhall SV Talk, Tuning & Tweaking 2 08-03-09 06:55 PM
Light Bulbs Speedy Claire Idle Banter 36 13-01-09 01:19 PM
Ford Mondeo - changing headlight bulbs Tigerrrr....... Idle Banter 4 24-09-08 02:03 PM
light bulbs Quiff Wichard SV Talk, Tuning & Tweaking 1 26-04-05 11:54 PM
Light Bulbs Nekkid SV Talk, Tuning & Tweaking 9 19-11-04 09:09 PM
