Old 24-01-08, 09:52 PM   #1
sv650k4
Default dose the 99-02 wheels fit the 03 onwards & wot do you need 2 do 2 use them?
as title says dose the 99-02 sv650 wheels fit the 03 onwards model???or wot dose it involve 2 use the older model wheels in the newer bike???
plus wot other suzuki wheels will fit the 03 onwards sv650?
Old 25-01-08, 11:53 AM   #2
sv650k4
Default Re: dose the 99-02 wheels fit the 03 onwards & wot do you need 2 do 2 use them?
anyone???
Old 25-01-08, 01:51 PM   #3
Rear wheel is the same, just swap the spacers and bearings. Maybe sprocket carrier, unsure on that. Front wheel... I think can be made to fit, but I don't know exactly what's involved, it's not identical but I seem to recall it can be done with spacers.
Old 25-01-08, 01:54 PM   #4
sv650k4
why dose the bearings have 2 be changed on the rear?and plus when u also say the sprocket carrier needs changed i take it ther different from each other?and apart from them things u say 2 do should the rear go straight on?
Old 25-01-08, 06:53 PM   #5
The axle's a different size, so the pointy one won't fit through curvy bearings. Otherwise it's the same wheel. The sprocket carrier might work, I'm not sure on that, but if you'regetting spare wheels it's not a big issue, you can just swap carriers.
k3 onwards wheels wanted MG#43 Stuff Wanted 0 01-12-07 09:09 PM
k3 onwards clock req. drwracing Stuff Wanted 2 05-07-07 09:53 PM
Radiator - K5 Onwards Steve_God Stuff Wanted 0 29-05-07 08:35 AM
4 wheels good, 2 wheels better Dysparunia Bikes - Talk & Issues 6 30-11-06 07:37 AM
K3 onwards Rad chunkytfg Stuff Wanted 1 28-06-06 04:50 PM
