Old 11-02-08, 08:57 PM   #1
Brooga
Default Newb here! huzzah! and help...
Hello all, lurked a while.. recent direct access pass (3 months) and recent aquisition of a fully faired yellow 02 curvy (2 months) so far just sunday rides and a few !COLD! commutes..
So, thought I'd say hello since this amazing little bike has me under her spell.. shes a bit tatty (dropped, plastic scuffs only..WASNT ME!), been around the block a few times and has been a touch neglected, but now shes come to a good home! cos ima loveee and cuddlee and lick herrr... .... ....*shakes out of day dream*.. ..
I've noticed a few minor issues with her that I'm hoping the wealth of knowledge here can help with, 1st of which is neutral.. doesnt seem to matter how gentle or hard I am with that lever, slipping clutch, holding different various revs I cannot for the life of me find neutral with the engine running, as soon as I turn her off.. POP its there.
Next on my agenda is cut outs, it always happens pulling away or rather attempting to. Theres no complaint from the engine as if I was giving too little revs, she just sometimes decides to cut.. tick-ZZzz..
And uhm.. well thats my main concerns for the moment, other than that shes beautiful.. not that I'd know different with my lack of knowledge.. haha..
Oh and, shes also due for a damned good polish!! which Im sure I'll not be able to resist posting the results from..
Thanks in advance!
Old 11-02-08, 09:04 PM   #2
Blue_SV650S
Default Re: Newb here! huzzah! and help...
Welcome
Your clutch is dragging, check there isn't too much freeplay in the cable and set the rocker arm up correctly - page 2:17 of this manual (http://www.sv650.org/SV_service_manu..._Maintence.pdf)
If after you set this up it is still playing up you have a warped or sticking clutch
Old 11-02-08, 09:07 PM   #3
Biker Biggles
Biker Biggles's Avatar
And check your engine oil level and chain tension are correct.Both can affect gear selection.Then check that the gear lever is well lubed where it pivots on the footrest.
And welcome to the madhouse.
Old 11-02-08, 09:08 PM   #4
Brooga
Thanks for the swift reply Blue, ive noticed also that she wants to pull from time to time with the clutch fully held.. is that also a symptom?
Old 11-02-08, 09:12 PM   #5
Brooga
Biggles, thanks! The oil was checked and topped up recently, holding a good level now also the chain was tensioned shortly after I bought the bike its also holding up.
Old 11-02-08, 09:24 PM   #6
Lozzo
Yes, get someone who knows what they're doing to show you how to adjust it. Check the oil level while you're at it.
Old 12-02-08, 02:38 PM   #7
pencil shavings
also, check you idle, if that is set too low it can cause the bike to randomly cut out.
Old 12-02-08, 03:14 PM   #8
dyzio
dyzio's Avatar
+1, once you've got your engine properly warmed up set your idle speed. I had a few cut outs, then I've changed it to 1k5 revs.
Welcome to the .org
Old 12-02-08, 09:01 PM   #9
Brooga
Thanks for the suggestions everyone, I've got alot to play with this weekend!
dyziowg: Can I ask where you got that single seat cowl? looking to get one in the near future. Also, are you going to upload pictures with the full fairing? looks like a right tidy bike at the moment!
Old 12-02-08, 09:28 PM   #10
dyzio
dyzio's Avatar
I didn't have the time to give it a proper clean and a photo sesion since I've fitted the lowers, here's a shot from a mobile...
I got the cowl, like most off my stuff from... here keep an eye out on the for sale/stuff wanted section.
newb paulmsv650s Idle Banter 19 19-03-09 09:04 PM
hello from a newb magicrat Idle Banter 24 15-02-08 04:35 PM
Hello from another newb tony00001 Idle Banter 14 28-08-07 04:03 PM
Newb - Yep another one! BonnieLass Idle Banter 27 02-05-07 03:22 PM
newb emaildell14 Photos 23 15-08-06 11:27 AM
