Old 15-02-08, 02:27 PM   #1
pencil shavings
Default Full screen problems
I have a 22" Samsung 2232bw monitor for my pc but when i play DVDs it never fills the whole screen? But when i streem tv and the like off the internet it does fill the screen. is there a setting that i have missed that i need to change?
thanks
Old 15-02-08, 02:29 PM   #2
plowsie
Default Re: Full screen problems
What program you playing the DVD's in?
Play them in Media Player, right click, press full screen.
Old 15-02-08, 02:38 PM   #3
pencil shavings
yep i use media player because its simpler than the other DVD player my comp has (cant think of the name now)
yeha i do that, but it still does not fill the screen. i know some DVDs have the black boarder on the top, because of wide screen, but mine is wide screen so it shouldnt suffer from this much. but also there is about 3 inchs horizontal on each side of black boarder which is the problem (as well as the borader on the top)
does that make more sence?
Old 15-02-08, 02:40 PM   #4
plowsie
Yarp a little, have you fiddled around with your monitor properties?
What system are you running?
Old 15-02-08, 02:42 PM   #5
G
Doesnt WMP optimise, so it wont go so big that it pixilates
Old 15-02-08, 02:43 PM   #6
plowsie
Thats what i thought, but, its a DVD, it shouldnt be that bad...
Old 15-02-08, 02:48 PM   #7
DoubleD
some films are extra widescreen* so you will still get the black boarders top and bottom. It will do the same on your TV as well if you have a widescreen TV.
*This is my technical term
Old 15-02-08, 02:49 PM   #8
pencil shavings
yep, its all been set up fine, right resolution, all drivers installed. ive got a dell dimention 5150 standard spec apart from ive now got 3Gb RAM. 2Ghz Intel Graphics Media Accelerator 950, 128MB PCI Express x16
Old 15-02-08, 02:51 PM   #9
pencil shavings
no i dont use this as my tv, just for streaming off the internet http://www.cucirca.com/2007/01/30/lo...-pilot-part-2/ like if it watch this, the second one, the screen fills.
Old 15-02-08, 02:53 PM   #10
pencil shavings
i just checked somthing else, if i play music in MWP and go to graphic view on the now playing option, click full screen it completly fills the screen.
DB Screen... or Sport Touring Screen? opinions plz :) Paul the 6th Bikes - Talk & Issues 21 07-04-09 08:15 PM
My HD is full Blue_SV650S Idle Banter 8 12-10-08 06:54 PM
Major problems getting an iridium DB screen pupdog123 SV Talk, Tuning & Tweaking 17 07-03-08 11:10 PM
Akrapovic full system or yoshi full system ? ? ? hall13uk Exhausts 40 15-08-07 11:44 PM
full system sv650s_guy Exhausts 1 16-01-06 12:31 AM
