First the confession:
When I was reading before on the forum about how difficult people were finding it to bleed the brakes I've got to admit I was feeling a bit smug, having bled car brakes more times than I can recall and also having had no trouble with the rear brake on the SV..... And then I decided to change the fluid in the front brakes. Well, what a bludy job it has been! I've finally got it 'sort' of done, but the travel in the front brake lever is maybe more than it was before. ![]() ![]() ![]() And a couple of questions: I want to do the TRE mod on my SVK1 tomorrow, according to the method giving in the 'How To' topics, and I was wondering what to use in order to shrink the cable wrap I have(to seal the cut cable ends). I've got a heat gun but I'm a bit concerned ![]() ![]() Is a well lubed throttle supposed to snap closed when released? ![]() |
Brakes:
Try, Try and Try again. Tap the lines, wiggle em around etc to get it all out. Heat Shrink: Heat gun should be fine, in light doses. Throttle: Pretty much.
'52 Curvy S | So good.....it made me want to trump! If at first you don't succeed - use more gaffa tape. |
The TRE mod in the 'how to' is well written and illustrated, but I think making it more difficult than it needs to be ...
You can attack exactly the same wires at the CDI/ECU unit itself, and all you need to do there is lift the rear seat and unplug the wires from the CDI/ECU; not take half the bike apart to get to the same wires, but under the tank! ![]() Anyhoo Have you tried a 'reverse bleed' on the brakes? |
I always use a cigarette lighter for heat shrink, you won't find that tip in the haynes manual because it sounds so bodgey but it works
#5 | |
Knob faced knobster
ditto
2001 SV650 in shimmerin green, Not broken anymore |
Also, check your throttle cable, might be worn. Mine didn't snap back for a while, then it went almost to the extent that I couldn't drive- it was hanging on by a single thread.
bleeding brakes can sometimes be a nightmare lol you just have 2 keep on and on at them!i ended up buying the we sealy pumping gun kit it works very very well!
Bleeding brakes: you can do it just fine by treating it like a car system and squeezing then closing the bleed nipple etc.
TRE: yes, do it at the ignitor unit, it's far easier, but don't expect an extra 3,000,000bhp, just a bit of extra tug there. Heat shrink, the adhesive backed stuff is ace, really good seal and protection, and yes just shrink it with a lighter. Zippos rule.
#9 |
+1 on all this.
Just keep bleeding..... being extra careful not to release the lever with the bleeder valve open. Another lighter user for heat shrink tubing. ![]() |
#10 |
Bleedin' Brakes! | Grinch | SV Talk, Tuning & Tweaking | 54 | 03-07-08 10:53 PM |
Am I shrinking, or is everything else getting bigger? | K | Idle Banter | 41 | 14-07-07 05:44 AM |
Shrinking Leather. | Steve H | Idle Banter | 9 | 15-05-07 10:29 PM |
Bleedin' Brakes! | Phantomtek | SV Talk, Tuning & Tweaking | 4 | 17-03-07 09:35 PM |
The Bleedin' Brakes! | snoopy | SV Talk, Tuning & Tweaking | 29 | 16-04-05 04:49 PM |
