Old 20-02-08, 11:20 AM   #1
shelleyamy
Default Front pad noise
I’ve not been that impressed with the front brakes on my 2000 SV, and have been thinking of upgrading the pads.
It already has braided hoses, so next thing to look at would be the pads.
Bearing in mind I thought my forks would benefit from progressive springs, bought a new set, went to fit them, only to find it already had them fitted.
Thought I would go down the sintered pad route, but thinking about the noise my brakes make at the moment (sound like rusty discs) is this the sound sintered pads make anyway?
I will pull out what’s in there now and check before I splash out, but what I am I looking for, do standard look different from sintered?
Mike
Old 20-02-08, 02:01 PM   #2
Default Re: Front pad noise
First things first if your brakes are making noise are the pads worn out? Are they dragging?
Old 20-02-08, 02:10 PM   #3
and If in my case they are full of crud, they will bind and make dragging noise. Your calipers sound like they need a service. Isn't that right chris
Old 20-02-08, 02:12 PM   #4
Yes your's were properly full of crud
Old 20-02-08, 02:16 PM   #5
forgot to ask you earlier...have you managed to free up the rear caliper yet?
Old 20-02-08, 02:18 PM   #6
Not yet
Old 20-02-08, 04:14 PM   #7
shelleyamy
Plenty of meat left on em, and they only make a noise when applied, their not dragging.
Mike
Old 20-02-08, 04:16 PM   #8
If its brake squeal then nothing to worry about, a clean up and some copperslip on the backs of the pads will sort that.
afaik the sintered metalic pads tend to be a coppery colour
Old 20-02-08, 04:20 PM   #9
johnnyrod
johnnyrod's Avatar
Sintered pads do make a noise, a sort of hissing/gentle scraping/whooshing or if you're really going for it, they can sing to you too. Once you get beyod singing you're usually bouncing the back wheel a bit and clattering the chain.
Old 20-02-08, 04:45 PM   #10
shelleyamy
No not a squeal, more like sand paper on metal.
Front cylinder noise andyb SV Talk, Tuning & Tweaking 9 10-07-07 05:27 PM
Rattling noise from front cylinder Steve226 SV Talk, Tuning & Tweaking 14 30-12-06 05:18 PM
Knocking noise in front fork k3lls SV Talk, Tuning & Tweaking 20 29-06-06 04:12 AM
Major front end noise!!!! svrash SV Talk, Tuning & Tweaking 5 26-05-06 06:33 AM
knocking noise from front end dmracing SV Talk, Tuning & Tweaking 13 18-02-06 09:25 AM
