Old 25-02-08, 10:16 PM   #1
SAMMY650
Default Ever heard of this?
Quick question....Has any one ever heard of having steel braided FUEL hoses?
If so what difference does it make?
Old 25-02-08, 10:21 PM   #2
Lozzo
Default Re: Ever heard of this?
None.
HTH
Old 25-02-08, 10:49 PM   #3
embee
embee's Avatar
It's simply the pressure rating. For typical carb applications the fuel pressure is a few psi (0.2 Bar say), for most injection systems it'll be a few Bar (typ. 3Bar).
The different types of hose are well demonstrated here
Old 26-02-08, 01:58 AM   #4
Yes heard of them, on the SV they make no difference, they do hold more heat than a nylon line, which can affect things if you're building a nitrous system, but I'm guessing you're not.
SV runs very little fuel pressure so you don't need them, if you were using a blow through turbo or something else needing silly fuel pressures then you might want some.
All that said... they look blingy
Old 26-02-08, 06:04 PM   #5
andyharding
I work for a hydraulic hose company and they make no differance what so ever. Unless you are using them on a high pressure injection system e.g wagon/car, even then they flex with the pressure and can give massive fueling problems, hence why we replace all injection lines with steel pipe.
I think it must purely be for looks. Cause everyone likes a bit of bling
Old 26-02-08, 07:00 PM   #6
independentphoto
One minor advantage is resistance to chafing, but you'd need to have excessive length or movement to cause that on a bike.
Garry
Old 26-02-08, 07:07 PM   #7
Jester666
Bling Bling Bling!! Thats it!!
Have you ever heard of.... 14990 Idle Banter 28 16-08-08 01:02 PM
Anyone heard from Tara Pennine Massive 2 03-10-06 07:53 PM
Heard on the way to work... Stingo Idle Banter 2 10-03-06 09:00 AM
Just heard this Stingo Idle Banter 5 01-03-06 03:16 PM
No doubt you'll all have heard it!! Stingo Idle Banter 2 20-02-06 07:17 AM
