Old 28-02-08, 08:13 PM   #1
sv_steve
Default removing tank pad and glue
Need to remove an old tank pad, a self adhesive oxford spine type. Thinking best to warm it up with a hairdryer and peel off slowly, but what about removing any residue of the glue and making sure the surface is clean before applying the new one ive bought. presumably a solvent, but what is safe to use on the paint/laquer?
appreciate your advice
steve
Old 28-02-08, 08:45 PM   #2
Svkid
Default Re: removing tank pad and glue
heat to get pad of then washing up liguid on residue and rub in with soft clothe, leave for a while then scrape of with fingernail or something not too sharp and then tcut any marks and buuf it all up
Old 28-02-08, 08:49 PM   #3
sv650k4
aye you would be best 2 heat it up a bit other wise it will maby do a bit of damage 2 the paint work.
Old 28-02-08, 10:40 PM   #4
sv_steve
thanks for that... would seem ironic to damage paintwork, removing something thats designed to protect it!! lol
Old 29-02-08, 09:46 AM   #5
maultin
whitye spirits might help (depending what type of glue has been used)
it will not damage the paint, but might help to soften the adhesive
Old 29-02-08, 12:41 PM   #6
DoubleD
warm it up first as said, then you can use petrol to get the sticky stuff off which will also clean the area up nice for the new one to go on.
I used a little bit of petrol on a rag to remove the sticky stuff after I took off all the warning stickers. I also cleaned with water and applied a bit of polish afterwards as well.
Old 29-02-08, 01:14 PM   #7
sv650k4
petrol works very well takeing the remains of something like that off!
Old 29-02-08, 01:43 PM   #8
Yup petrol will do it, make sure to smoke at the time ... keeps you sharp
Old 29-02-08, 11:14 PM   #9
Wd40
Old 01-03-08, 03:52 PM   #10
jumjum_0214
Muc off motorcycle cleaner
Removing the petrol tank yardar83 SV Talk, Tuning & Tweaking 7 12-05-09 10:39 PM
Removing fuel tank dents. Magnum Bikes - Talk & Issues 20 05-01-09 05:43 PM
Tank drain repair - petrol safe glue? FreshAL SV Talk, Tuning & Tweaking 4 22-08-07 07:33 AM
Removing Tank Protectors Maestro Bikes - Talk & Issues 0 15-05-07 03:33 AM
Removing the petrol tank Suzuki sticker? PaulyMac SV Talk, Tuning & Tweaking 9 13-11-06 09:48 PM
