Old 28-02-08, 10:43 PM   #1
flymo
flymo's Avatar
Default weeping nipples :-0
my nipples are weeping, what can I do ?
I have a brake bleed nipple that appears perfectly sound and clean but it seems to weep fluid up the threads. Anybody know any tricks to sort this?
I've seen a paste similar to thread lock before now thats intended for bleed nipple threads. Any idea what it is and where I might get some?
Old 29-02-08, 01:58 PM   #2
jambo
jambo's Avatar
Default Re: weeping nipples :-0
The bleed nipple should have a seal in the caliper that it goes into, is that in good nick?
Old 29-02-08, 02:00 PM   #3
Alpinestarhero
tried using a bit of PTFE (teflon) tape round the thread, when you put the bolt on?
Matt
Old 29-02-08, 02:05 PM   #4
jumjum_0214
I had this problem so i just nipped up the nipple Its ok now
Old 29-02-08, 02:14 PM   #5
flymo
flymo's Avatar
Yeah the seals 'appeared' to be fine but I may need to remove and check again. I have some replacement hoses coming that I need to fit anyway so thats no problem.
I like the PTFE idea, especially for the brake bleeding phase to save fluid leaking everywhere.
I've had new nipples supplied before that came with a type of threadlock compount, wondered if anybody had seen/used this before.
Old 29-02-08, 02:34 PM   #6
Blue_SV650S
The nipple seals via the conical end, make sure the end and its recess is clean. Putting PTFE (or whatever) round the threads is like sticking a bung in the end of an overflow pipe as something is overflowing … it might stop it coming out for a bit, but its not solving the problem
Old 29-02-08, 02:45 PM   #7
Baph
Everytime I touch my nipples (oo-eer) I take the PTFE off & put new stuff on there. Habit I suppose.
Old 29-02-08, 02:56 PM   #8
flymo
flymo's Avatar
Yeah I understand that, I think where the ptfe might be useful is during brake bleeding itself. As soon as you undo the nipple each time you usually get fluid escaping up via the thread, PTFE might well stop this. But once bled yeah the pressure should be totally contained by the nipple seal itself.
Old 29-02-08, 03:02 PM   #9
Blue_SV650S
So it seals ok, just weeps when you bleed right?
If so - what are you worried about?!!?
Old 29-02-08, 03:19 PM   #10
flymo
flymo's Avatar
No I think we are talking about two different things in the thread. My actual problem is that the system is weeping through one front nipple and the rear does the same when everything is supposed to be sealed shut and the nipples are tightly seated. For that part then there must be something wrong with the seal itself which I'll have to check out.
The other side of this is that I think PTFE tape (or this mystery compound that I cant identify) can be useful to prevent fluid ****ing all over the place when bleeding the calipers.
Weeping Fork Seal plowsie SV Talk, Tuning & Tweaking 12 15-04-09 02:54 PM
Nipples !! Banus SV Talk, Tuning & Tweaking 4 22-05-06 10:29 AM
nipples lovely nipples - slurp! madmal SV Talk, Tuning & Tweaking 1 08-02-06 08:40 PM
hairy nipples madmal SV Talk, Tuning & Tweaking 8 04-02-06 09:24 PM
Bleed nipples svrash SV Talk, Tuning & Tweaking 10 24-11-05 06:33 PM
