Old 11-03-08, 07:15 PM   #1
Girth
Default Spraying parts.
Going to spray the chain adjusters and brake mount on the thou.
I want the finished product to be black but not glossy.
Question is what primer and paint would anyone recommend?
Ta
Old 11-03-08, 07:18 PM   #2
Default Re: Spraying parts.
Chassis Black epoxy paint, sprayed from slightly too far away, gives a nice satin finish- if you spray a proper wet top coat it's glossy but if it air dries a little it takes the shine off.
Old 11-03-08, 07:22 PM   #3
Girth
you know of anywhere online that sells it?
Old 11-03-08, 07:28 PM   #4
I probably got mine from Frosts I think...
Old 11-03-08, 07:34 PM   #5
Girth
is this the stuff? http://www.frost.co.uk/item_detail.a...atID=&SubCatID=
Old 11-03-08, 07:37 PM   #6
That's it. No doubt there are loads of other paints that will do just as well, I think Halfords do a satin black wheel paint which would probably do the job... I tend to stick with what I know though. It might take you a couple of tries to get a good result, since basically what you're doing here is deliberately spraying badly
Old 11-03-08, 07:39 PM   #7
Girth
is it worth using a primer and a clear coat afterwards?
as you may of guessed this is my first attempt at spraying
Old 11-03-08, 07:43 PM   #8
I never have, with that stuff, I think it'd need a primer for aluminium but it sticks well to steel in my experience, if the surface is clean. Clear coat would probably make it glossy.
Hey, VHT do both a matt and satin epoxy black spray can- that'd make more sense than doing it my way really.
Old 12-03-08, 12:46 PM   #9
Dangerous Dave
Good stuff that!!!
Old 14-03-08, 12:34 PM   #10
Just did my pillion peg hangars, just used a few coats of el-cheapo satin black, holts I think it was.
This is after adjusting the RHS one with an angle grinder to make it work with the high level can.
Looks alright, can't see it taking long to rub through though where it touches boots.
Help Needed, Spraying gralln9 SV Talk, Tuning & Tweaking 0 19-04-09 06:20 AM
Spraying plastics. Tomtoms Bikes - Talk & Issues 3 19-02-09 02:27 PM
Powder spraying GRP Tilt Bikes - Talk & Issues 2 28-01-09 10:19 PM
Re-spraying diamond South & West Surfers 13 10-09-05 07:20 AM
Home spraying northwind SV Talk, Tuning & Tweaking 18 04-04-05 04:06 PM
