Old 18-03-08, 10:39 AM   #1
krhall
Default Gear change feels more clunky than usual?
Just noticed that my gear change feels a little more clunky than usual in the last two days. Is it just me or is there something that I can check or need to be aware of?
What could be causing this?
The bike is a K3 with about 16k on the clock. Commutes about 125 miles a week.
Old 18-03-08, 10:45 AM   #2
Razor
Default Re: Gear change feels more clunky than usual?
Chain tension.
Old 18-03-08, 10:48 AM   #3
krhall
Yeah it could be that actually - just had a false neutral on the A2 too. I can do that myself then (sort of).
Old 18-03-08, 03:52 PM   #4
sv650nutter149
would this cause it not to go into 6th at high speed then?? bout 120 9 tho revs?
Old 18-03-08, 04:26 PM   #5
BILLY
Low on oil!
Old 18-03-08, 04:46 PM   #6
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Originally Posted by Razor View Post
Chain tension.
i would bet confidently that this is the cause, mine did exactly the same thing until i adjusted it
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 18-03-08, 05:03 PM   #7
Dangerous Dave
Check the tension of the chain first, but always give the foot controls and gear linkage ends a good lube every now and again!
Old 18-03-08, 05:07 PM   #8
thedonal
As above, then clutch adjustment, then clutch arm adjustment (behind front sprocket) cover
Gear change problem-can't get past 2nd gear muzikill SV Talk, Tuning & Tweaking 8 14-03-10 10:10 PM
Clunky gear changes Holdup Bikes - Talk & Issues 3 02-04-09 01:04 PM
Gear change problem-can't get past 2nd gear muzikill SV Ecosse 8 13-09-07 07:45 PM
