Old 21-03-08, 05:54 PM   #1
Wideboy
Evel Knievel
Wideboy's Avatar
Talking car electrics help plz
Problem: every time i press the button to switch on my rear window heater it blows the fuse
Things done:
i've ripped the dash out, inspected the button = fine.
wire's going into the tail gate from the roof = fine, as far as i can see.
disconnected the wires from the window to break the circuit = still blows.
all this has resulted in a lot of blown fuse's and very pished off me!
the fuse is shared with the horn but the horn doesn't blow the fuse.
tomorrow I'm going to check the relays but is there anything else??
05 DRZ400E
RIP hovis
Old 21-03-08, 07:57 PM   #2
Default Re: car electrics help plz
relays are prob the way to go, rear window heaters use lots of power and the fuse will pop to stop the wiring getting hot.
Old 21-03-08, 08:23 PM   #3
Biker Biggles
Biker Biggles's Avatar
But not with the heater element disconnected?My vote is for a problem in the switch,or a chafed wire earthing out in the live feed to the rear window.
Old 21-03-08, 09:03 PM   #4
Ruffy
Ruffy's Avatar
Try disconnecting the feed from the relay to the window heater element at the relay end, checking that the relay still clicks when the switch is operated (check for 12V at the output connection of the relay.) If this blows the fuse then the problem is probably the switch or relay, otherwise the wiring from relay to the heater element.
You can also disconnect the switch feed at the relay to isolate that section of the circuit to check if that's the problem.
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Old 21-03-08, 09:09 PM   #5
Richie
fantabulas
Richie's Avatar
stick a nail in the fuse holder......
no please don't.
My Flickr photos
Old 21-03-08, 09:20 PM   #6
Wideboy
Evel Knievel
Wideboy's Avatar
the relay still clicks after the fuse has blown is this normal? (i know jack about electrics)
no please don't.
don't tempt me, luckily i got the haynes out otherwise i would be royally in the s***
failing this i will be pushing the bloomin thing off a cliff
05 DRZ400E
RIP hovis
Old 21-03-08, 10:32 PM   #7
Ruffy
Ruffy's Avatar
It can be normal. A relay is basically a remote control switch: The switch you use in the car operates the relay, then the relay operates the heater circuit. If the power to the switch on the dash is fed from a different fuse than the heater circuit then the relay will still work but no power will get to the heater.
This probably means there's a fault in the heater wiring somewhere (probably insulation rubbed off on a panel edge/hole) or the fuse is too low a rating (what rating is fitted - has it just started blowing recently? BTW, what type of car is it?)
Old 21-03-08, 10:35 PM   #8
Wideboy
Evel Knievel
Wideboy's Avatar
no it just randomly went on Saturday night, the light in the button dont light up anymore when you press it
05 DRZ400E
RIP hovis
Old 21-03-08, 10:50 PM   #9
tigersaw
tigersaw's Avatar
got a meter? Can you measure resistance from the wire you pulled off the heater element (live feed) to chassis - when heater not turned on/ fuse out - should be high or infinite, low reading suggests cable damage or fault.
If its french then I suggest you give up now.
Old 21-03-08, 11:18 PM   #10
Richie
fantabulas
Richie's Avatar
yarp...
My Flickr photos
What now?...electrics Dave20046 SV Talk, Tuning & Tweaking 138 21-04-09 09:48 AM
No electrics toffo SV Talk, Tuning & Tweaking 3 10-03-09 05:34 PM
Electrics. seandixie SV Talk, Tuning & Tweaking 13 15-02-08 02:07 PM
electrics dead - what to do? weazelz SV Talk, Tuning & Tweaking 6 18-02-07 03:08 AM
Urgent Electrics Frogman Stuff Wanted 3 22-09-06 12:54 PM
