Old 24-03-08, 12:19 PM   #1
Kinvig
Default front tyre removal - I'm destroying my wheel
Can anyone help?
I'm totally destryong my front wheel - I've trying to remove the tyre to fit tkc80s.
All that I'm ending up doing is putting dings into my wheel rim.
The tube is deflated & the bead is broken.
I'm a bit naffed off as I'm ruining a £90 wheel.
Help? Advice?
Dirk
Old 24-03-08, 12:24 PM   #2
husky03
Default Re: front tyre removal - I'm destroying my wheel
you got the rim protectors ?
Old 24-03-08, 12:26 PM   #3
Berlin
6" pieces of thick hose pipe split lenthways and slid onto the rim.
Old 24-03-08, 12:44 PM   #4
Are the beads pressed in to the well on the opposite side to where you're levering? If not it'll never come off, breaking the bead is a start - you need to make sure that they stay down the well.
Old 24-03-08, 01:48 PM   #5
flymo
flymo's Avatar
a little tyre soap or washing up liquid will help too to let them slide off
Old 24-03-08, 04:58 PM   #6
Kinvig
Thanks for your help guys!
Well, eventually I removed the wheel & fitted the heavy duty inner tube & tkc80 tyre.
I'll be taking those strips of garden hose on my journey! Nice trick.
front wheel removal tool? w1ll15 SV Talk, Tuning & Tweaking 11 20-09-10 02:35 PM
SV650 Front Wheel - Do any other Suzuki models use the same front wheel? williamturner1 SV Talk, Tuning & Tweaking 11 30-05-10 02:31 PM
Removal of gixer 600 front wheel. Help needed! phil24_7 SV Talk, Tuning & Tweaking 12 02-06-08 10:10 PM
Front wheel removal Elio SV Talk, Tuning & Tweaking 7 09-03-07 07:56 AM
Front wheel removal allen key - urgent help needed please Stu SV Talk, Tuning & Tweaking 13 18-02-07 12:35 AM
