Old 31-03-08, 08:46 AM   #1
k146
Default Led Indicators
I know this has probably been covered a thousand times before
so basically ive put led indicators on my bike and as expected they flash to fast
how do i slow them down, what do i exactly need, where do i get it from and where does it go in the bike?
pics would be helpful
help please
its a 2005 faired sv
cheers guys n gals
xx
Old 31-03-08, 08:55 AM   #2
Default Re: Led Indicators
resistors from maplins or a variable motrax flasher unit, i couldn't be ar@ed so i put the OE ones back on.
Old 31-03-08, 09:09 AM   #3
k146
motrax dont do a flasher unit for suzukis they do a universal one, will this work and where does it go?
Old 31-03-08, 09:14 AM   #4
yea thats the one, it goes under the riders seat on the k3 not sure about the k5.
Old 31-03-08, 09:16 AM   #5
k146
do u reckon some one will have pictures of where it will go?
do u have to cut wires?
im not worried if i have to just need to know which ones to cut
im not really up to spec on all this as u can tell ha ha
Old 31-03-08, 09:27 AM   #6
the motrax plug in relay just "plugs in" the resistors have to be soldered in. someone will be along shortly to let you know if its in a diff place to the k3.
Old 31-03-08, 09:54 AM   #7
silent11
http://www.project-r.co.uk/instructions_flasher.htm
if you read the instructions it will show you what to do to the relay and the motrax one
its basically take wires from suzuki relay and connect them up with the motrax universal one
Old 01-04-08, 07:23 PM   #8
scoobinater
Buy the universal 2 pin electronic flasher from motrax and then use this to install it:
http://www.customdynamics.com/custom...00_flasher.htm
Worked great for me. I used a different flasher, but as long as it's a 2-pin model you should be fine. Here's the one I bought for my 2007 SV:
http://www.vfxkits.com/c275229.2.html
Old 07-04-08, 06:45 PM   #9
ulfeh
hi,
i need some help.
where can i find the turn signal relay on a sv650 2008?
i replaced original blinkers with led, and they flash much to fast. (i replaced the blinkers and relay on my wife's 650 -00 but the relay is not at the same place on my -08. (i don't know if it looks the same))
thx,
ulf
Old 07-04-08, 06:51 PM   #10
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
slightly related note, presumably you only need to purchase one flasher unit for your bike, even if you are fitting LEDs front and rear, the DRZ is receiving some pimping next weekend...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
Which indicators? aimhamilton Bikes - Talk & Issues 7 01-04-06 04:57 PM
Indicators mike_b Stuff Wanted 2 13-01-06 02:03 PM
Indicators enabb For Sale - SV's and SV related items 2 11-12-05 10:42 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
