Old 31-03-08, 02:03 PM   #1
SV PILOT
Default Charging the battery
When charging the battery, I'm going to disconnect the battery from the bike. Now, I have a META def com T alarm. Disconnecting the battery from the bike, will this affect the alarm when I reconnect the battery? Cheers
Old 31-03-08, 02:44 PM   #2
ThEGr33k
Default Re: Charging the battery
Might just be really annoying and set it off about 400 times... They have their own built in batteries so you should be fine
Old 31-03-08, 03:27 PM   #3
SV PILOT
This is an absolutely noobie question but how do I get to the battery? Cheers
Old 31-03-08, 03:30 PM   #4
beaniebikerbabe
sv pilot mine is under the seat, have to take pillion seat off then front one. !
Old 31-03-08, 03:38 PM   #5
SV PILOT
Cool, I kind of thought that but after getting the back seat off how do I get the front off? I've had the back one off but not front as of yet. Cheers
Old 31-03-08, 03:53 PM   #6
ThEGr33k
The plastic pieces (grayish black colour) take them off. Then youll see the front seat mounts. Simply undo them and you should be sorted.
Old 31-03-08, 03:57 PM   #7
beaniebikerbabe
Wink Re: Charging the battery
hiya
take the little side bits off then there is screws to undo bit of a pain, but them seat lifts off then, battery under there.
Old 31-03-08, 05:05 PM   #8
Durbs
Yes, put the alarm in service mode if your model supports it or when you disconnect the battery the alarm will trigger a full response thinking you're nicking it. All alarms will have a procedure that needs to be followed before disconnecting the battery.
charging battery maclovin SV Talk, Tuning & Tweaking 6 13-01-09 09:44 PM
Charging the battery DANINPLYMOUTH SV Talk, Tuning & Tweaking 2 15-12-08 04:23 PM
charging the battery gico SV Talk, Tuning & Tweaking 3 02-04-08 05:39 PM
Charging/Battery: MrMessy Bikes - Talk & Issues 8 30-11-07 12:50 PM
Is battery charging? Warthog SV Talk, Tuning & Tweaking 9 22-06-06 09:36 AM
