Old 02-04-08, 08:24 AM   #1
SV PILOT
Default Bump start
Hello all, I posted some threads regarding my battery being flat not too long ago. I want to get a move on and charge it. I think the alarm will be an absolute pain, so my question is, could someone go through step by step of how to bump start my SV? I tried already but no luck, I'm just making sure that I did it right. Cheers.
Old 02-04-08, 09:16 AM   #2
cb5_keith
Default Re: Bump start
Turn ignition on, side stand up, hold clutch in and engage first (possibly second as in that vid, guess its just trial and error?), keep the clutch held in, F*cking leg it! LEG IT! ...slowly let the clutch out as your legging it and keep pushing as you feel it pushing back at you....hopefully the engine starts! Jump on like a mad man and riiiide away!
If first is a struggle, i guess try second :S
Only had to do this once
Good luck!
Old 02-04-08, 09:18 AM   #3
cb5_keith
I also found this....
BUMP!
Old 02-04-08, 09:29 AM   #4
SV PILOT
Cheers CB5 KEITH. Big help, I was half way their but I ran out of puff! I shall LEG IT as hard as possible! Say I do get it started and leave it running, will the battery be able to then start the bike normally?
Old 02-04-08, 09:31 AM   #5
Alpinestarhero
Get it running, and go ride it for an hour or something; if you can keep the lights off, keep the lights off. The battery should pick up some charge from the alternator
Happy bumping
Matt
Old 02-04-08, 09:35 AM   #6
cb5_keith
Go for a ride and get a charger!
Old 02-04-08, 09:41 AM   #7
flymo
flymo's Avatar
BUMP!
Yeah right, I'ld like to see somebody start a V twin like that! Battery charger would be the way to go
Old 02-04-08, 09:43 AM   #8
cb5_keith
Example of possibly the easiest bump start ever...
Old 02-04-08, 09:45 AM   #9
flymo
flymo's Avatar
Yeah, they probably do these videos with a bike that already starts easy, imagine doing that on an SV with a crap battery.
Old 02-04-08, 09:51 AM   #10
Alpinestarhero
Hard to bump-start a cold bike too. My dad bumped my bike for me in the summer, after a long ride (the reg/rec had failed and the battery drained) and it fired up right away
(down a hill, rolling, second gear - up on the pegs, then drop down on the seat as the clutch is dropped, bike fired up right away)
Matt
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
Bump Start? Not a Chance Viper SV Talk, Tuning & Tweaking 42 07-02-07 09:37 AM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
Bump Start? Not a Chance bbanna Idle Banter 3 09-01-70 02:39 PM
What does *bump* mean? Smiler33 Idle Banter 1 07-01-70 12:59 PM
