Old 08-04-08, 06:35 PM   #1
jonhunt
Default HID Kit
Anyone fitted one on there Bike on here.
I got the kit on my Car i have philips blue in the bike and they are brighter
Just wana no if anyone had any prob fittin them etc
Jon
Old 08-04-08, 07:29 PM   #2
Dan
Default Re: HID Kit
Jon
You're not seriously saying that your Philips incandescent bulbs are brighter than proper HID capsules, are you?
You must have some proper dodgy HIDs if they are.
Old 08-04-08, 07:43 PM   #3
Default Re: HID Kit
http://forums.sv650.org/showthread.p...ng+plain+sight
Old 08-04-08, 07:44 PM   #4
Dangerous Dave
Default Re: HID Kit
Chris and Northy both have, follow the links to their threads.
Old 09-04-08, 01:01 AM   #5
Default Re: HID Kit
You've having a laugh right?
The HID is seriously bright, way ahead of any filament lamp of sensible wattage.
As for fitting, it's not a drop in replacement, but not too hard. Your's a SV or SVS?
If it's SV then you cant use northys method of fitting them to the subframe, and I would advise finding a kit with at least 3' of HT wire from the ballast, and put the ballast(s) above the battery.
Maybe you could put one ballast in front of the carbs behind the headstock, but that space on mine's been full of wiring for so long I can't remember what it should look like
For comparision, a ballast is about 20 superkings plus a bit.
Old 09-04-08, 05:58 PM   #6
Default Re: HID Kit
I reckon the rear subframe might be a good choice for the N, opposite the reg/rec, tons of space in there and it's fairly ventilated too. That was my backup plan...
Old 09-04-08, 08:47 PM   #7
Default Re: HID Kit
As was my intention, except my kits wiring was too short.
