Old 17-04-08, 10:13 PM   #1
SV-net
Default New Chain Required
My chain is looking really unwell after the winter stood in the garage. I am going to replace it but not sure whether to get a standard Suzuki item fitted or another one? Suzuki wand 1 hour labour and ?130 for chain and sprockets which I thought reasonable or am I too easy going !!!
its SV650 K3 naked.
Your comments appreciated.
Old 17-04-08, 10:20 PM   #2
bad-sv650
Default Re: New Chain Required
how much is the hours labour? if it's around ?45 then thats not to bad.
stick to genuine parts.
Old 17-04-08, 10:23 PM   #3
If that's a quote for OE stuff fitted then it's not too dear.
You could certainly buy cheaper, but good stuff is worth paying for.
Old 17-04-08, 10:25 PM   #4
SV-net
?50 is for the hours labour for chain and sprockets fitted.
Sounds like I should book it then.
Actually the chain and sprocket set is only ?109.00 so its even better. You can see the set here if its of interest http://www.robinsonsfoundry.co.uk/sh..._k5/index.html
Old 18-04-08, 08:06 AM   #5
Biker_Billy
That might be a pretty good deal. When I looked into changing the chain & sprockets the OE chain is endless which requires removal of the swingarm - so for an hours labour thats pretty good.
Dont know if the OE chains are still endless tho?
Would be a good time to ask them to grease the swingarm bearings too...
BB.
Chain Always Loose, New Chain? RGSPro SV Talk, Tuning & Tweaking 8 02-07-10 10:05 AM
MCN help required. admin SV Talk, Tuning & Tweaking 49 29-09-08 10:18 AM
Morax Gold Chain Wax / Wurth Chain Wax glade Ancillaries 3 14-02-08 06:41 PM
Chain & Sprocket advice required. Jester666 SV Talk, Tuning & Tweaking 15 15-08-07 01:15 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
