Old 22-04-08, 08:58 AM   #1
Gazza77
Gazza77's Avatar
Default Mower won't start
I've been invited round to the in-laws for tea tonight, on the basis that I have a look at their petrol mower which doesn't want to start. I'm making an educated guess that having been sat all winter, a bit of fresh fuel might help; anyone any other suggestions as to what the problem is likely to be?
Formerly Blue K5 with added bits
Then Triumph Sprint ST with scottoiler and R&Gs & TOR exhaust
Now Benelli Tornado
Gazza77 is offline   Reply With Quote
Old 22-04-08, 09:01 AM   #2
Scoobs
Default Re: Mower won't start
Is it plugged in?
Old 22-04-08, 09:04 AM   #3
Gazza77
Gazza77's Avatar
Originally Posted by Scoobs View Post
Is it plugged in?
I've not seen it yet, I'll check that one first.
Now Benelli Tornado
Old 22-04-08, 09:34 AM   #4
tigersaw
tigersaw's Avatar
My easystart mower wouldnt start either after sitting all winter. Fresh fuel, plug out and a few pulls, clean plug and back in and off it went.
Old 22-04-08, 09:38 AM   #5
plowsie
Check the kill switch is off, sidestand isn't down, charge the battery if need be.
Old 22-04-08, 09:39 AM   #6
plowsie
You will get it started and they will say, while your there you might aswell finish the job
Old 22-04-08, 11:00 AM   #7
Gazza77
Gazza77's Avatar
They wish.
Now Benelli Tornado
Old 22-04-08, 11:05 AM   #8
Ed
Probably has a Briggs engine - they're indestructible. Make sure you've primed the engine - mine has a rubber push button thingy, you press it three times. No more or you'll flood the engine. Oh yeah, you need to hold the clutch in, it's a safety device. Finally make sure the air filter is clear of dried out grass.
Best way to start the day... flibble Idle Banter 2 03-03-08 09:54 AM
Won't start ! H SV Talk, Tuning & Tweaking 37 21-12-07 12:27 PM
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
So you've bought a lawn mower while out on your bike, how do you get it home? lynw Idle Banter 10 11-06-07 09:01 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
