Old 23-04-08, 08:13 PM   #1
olden mgroin
Default light problem.
hey all, iv'e a problem with my head lights. when i turn on the ignition they don't come on, but when i flick the high beam switch that works fine and the side lights are fine too. i should say i know very little about electrics but iv'e checked the obvious, fuses,wire connections,and bulbs are all fine.
Does anybody have any ideas.
Old 23-04-08, 08:24 PM   #2
Rich
Rich's Avatar
Default Re: light problem.
Are you sure the low beam elements are ok in the bulbs i've had the low beams go before. Have you tried new bulds?
RIP Hovis - Unlucky Boyo
Old 23-04-08, 08:30 PM   #3
olden mgroin
tried new bulbs still no joy. i now have two sets of bulbs. also bought new fuses just incase.
Old 23-04-08, 08:34 PM   #4
Rich
Rich's Avatar
Well im stumped too. Sorry im no help, sounds like a connection somewhere. Have you tried looking at the connectors behind the head unit?
Old 23-04-08, 08:39 PM   #5
olden mgroin
Thumbs up Re: light problem.
no worries, thanks for the input.
Old 23-04-08, 08:46 PM   #6
DoubleD
Have you looked inside the switch itself just to make sure everything is as it should be??
other than that not sure, wiring diagram might help you and a tester but duno how to do that kind of stuff.
Old 23-04-08, 09:15 PM   #7
Stig
Have a look at the connector blocks. Especially the one on the left hand side midway between the headstock and rider seat. You'll need to lift the tank to gain access. There is a possibility corrosion is either causing a short or an bad connection.
Old 23-04-08, 09:24 PM   #8
olden mgroin
thanks guys, i'll take a look tomorrow and post the outcome.
Old 24-04-08, 07:05 AM   #9
blueto
sounds like a faulty switch. have you got a multimeter>??
Old 24-04-08, 02:29 PM   #10
carsounds_dan
check the relay as-well as low and high beam are served by two different relays.
cheers
dan
Brake and back light problem. scotty73 Bikes - Talk & Issues 0 09-06-08 07:41 PM
has anyone ever had the FI light and got the code -C23 if so wot was the problem?? sv650k4 Bikes - Talk & Issues 8 28-01-08 12:19 PM
Odd electrical/light problem Ceri JC SV Talk, Tuning & Tweaking 25 30-12-07 07:58 PM
oil light problem oldsvrider SV Talk, Tuning & Tweaking 3 28-06-06 04:11 PM
Fuel Light Problem Bez SV Talk, Tuning & Tweaking 8 08-05-06 01:04 PM
