Old 26-04-08, 11:07 AM   #1
petevtwin650
Default How important is......
the length of the rear caliper hanger.
I bought, on the off chance it would fit, a caliper hanger from a Bandit 400 cos it looked kinda nice and a bit different.
As luck would have it, it's a perfect fit spindle wise and the shape is the same. However it's about 5 -8 mm longer, meaning the pads will bear in a slightly different place and presumably won't sweep all the disc now.
What do peeps think, before I go to the trouble of polishing up this little gem?
Well, actually Lissa goes to all the trouble.
Old 26-04-08, 11:50 AM   #2
sv650k4
Default Re: How important is......
will if you say the one you want 2 put on is 5-8mm longer then thats gona take your pads up/of the disk around 5-8mm then stick it on and see if your pads are going 2 be on the disk much and go by that really.
Old 26-04-08, 12:32 PM   #3
Dangerous Dave
This smaller size difference wouldn't cause a problem Pete, quite common with Suzuki!
Old 26-04-08, 06:33 PM   #4
petevtwin650
Was gonna stick it on and try and I am aware that if all the pad doesn't bear on the disc I'll eventually have pads that will touch without applying pressure on the disc itself. That's just a case of keeping a constant watch on them. Just wondered if there was any other problems. Guess not
Thanks guys
Old 26-04-08, 06:45 PM   #5
I suppose you could oval some of the holes. Maybe fill them afterwards with chemical metal. But that might be idiotic, I'm unsure It does look nice though.
Old 26-04-08, 06:53 PM   #6
dirtydog
Knob faced knobster
dirtydog's Avatar
I suppose you could oval some of the holes. Maybe fill them afterwards with chemical metal. But that might be idiotic, I'm unsure .
That's what i would do, but then some people do say i am an idiot
2011 Speed Triple 1050
Old 26-04-08, 07:18 PM   #7
Lozzo
Put a Bandit 400 rear disc on
Old 26-04-08, 07:23 PM   #8
petevtwin650
That'd work I guess, but I want, no need, a wavy disc.
Old 26-04-08, 07:32 PM   #9
arenalife
Considering the low power needed from the back brake anyway I'm sure it'll be fine. You're reducing your area by going wavy anyway eh?
Old 26-04-08, 07:35 PM   #10
petevtwin650
I ride two up everywhere, so actually rely on the back brake a lot. 6k to a set of pads. And I've already got a wavy on. Yes I am a tart!
important message hovis Idle Banter 9 06-04-08 09:12 PM
Very important! Very important! Pedrosa Bikes - Talk & Issues 23 18-06-07 03:41 PM
VERY important poll keithd Idle Banter 24 29-09-06 08:10 AM
Some important events Ed Idle Banter 1 22-02-06 08:47 PM
Important issue howardr SV Talk, Tuning & Tweaking 3 16-07-03 12:27 PM
