Old 30-04-08, 01:24 PM   #1
Draper
Default Looking to clean up the forks
after seeing that sv restorer, decided over the summer i might do a few bits and bobs like giving the forks a sand and polish etc. Obviously i'll need paddock stands to get the front wheel off or whatever, would this be any good?
http://www.mandp.co.uk/productInfo.aspx?catRef=901466
i know people say is it worth having your bike fall off at the cost of an extra bit of money, but i am definately looking for budget here (student desperately looking for summer work!)
Draper
Old 30-04-08, 01:30 PM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: Looking to clean up the forks
the only thing about using one of those front stands is you wont be able to move the forks while youre trying to polish them. I normally just give my forks a rub down with wet and dry paper then a quick spray over with some silver or black paint (depends what i've got in the garage) and it makes it easier to do if you and turn the fork lowers around as you're working on them
2011 Speed Triple 1050
Old 30-04-08, 01:36 PM   #3
Draper
but they should do the job? just abit dubious about the price, considering its a pair
what paint do you use for the forks then? was thinking about just polishing them up proper
cheers,
Draper
Old 30-04-08, 01:41 PM   #4
dirtydog
Knob faced knobster
dirtydog's Avatar
Yeah they'll probably be ok for the job, 1st time i did the forks i had it on a rear paddock stand and then a jack under the engine but it was rather unstable. I normally just us e the halfords spray cans and then some spray lacquer over the top. Only problem with that is they pretty much need doing after every winter as spray can lacquer is rather soft. The polished forks do look good but I'm far to lazy to keep them looking all shiney.
Old 30-04-08, 01:43 PM   #5
Draper
thanks for the info dirtydog, i'll get ordering some stands and then get cracking on the bike in a few weeks
Old 30-04-08, 02:36 PM   #6
You don't need a stand to get the forks out. A jack or a couple of blocks of wood do the trick fine.
Old 30-04-08, 03:14 PM   #7
sv_rider1990
Iv just done the wet and dry and polish with autosol method and it looks a million time better i didnt take the wheel off it was just a quick job to see how it looks i'll post up pics soon - am going to do a proper job and take the wheel off etc probs just put rope through the frame and put the bike on the rear paddock stand tie it to a rafter in my garage and do it that way.
Old 30-04-08, 03:30 PM   #8
You can just lift the weight on to sidestand and back wheel to get the forks out, tis the simplest way.
Old 30-04-08, 05:11 PM   #9
Draper
do i need to get the forks out?
i was just gonna get wheel out the way so could polish easier... or am i missing something here (self confessed eejit)
Old 30-04-08, 05:16 PM   #10
No... but you can still just use a trolley jack to do that rather than paddock stands
USD GSXR1000 k1 forks | standed forks - curvy Nicky S SV Talk, Tuning & Tweaking 113 07-09-09 01:12 PM
Clean!! its soo clean!! + chain question John 675 Photos 13 07-03-09 07:14 PM
Just had a clean Franco1 Photos 11 03-05-06 10:59 AM
clean SV K5 jonhunt Photos 11 27-12-05 04:39 PM
How clean is yours? suzsv650 Bikes - Talk & Issues 16 27-11-05 04:31 PM
