Old 01-05-08, 01:07 PM   #1
Tiger 55
Default Indicator relays
I need a 10w relay for the Trumpet but I can only find 21w jobs.
Question is will a 21w relay cause my flashers to flash not at all, much slower, slower, the same, faster or much faster?
Or point me at a replacement 3 pin, 10w relay please folks because one stupid problem after another is doing my nut in!
Old 01-05-08, 02:14 PM   #2
sv650k4
Default Re: Indicator relays
i may have one sitting about somewhere il have a look and if i do il let you no.
Old 01-05-08, 07:25 PM   #3
Tiger 55
That would be the greatest thing since the jelly baby. Thanks mate, I'm standing by...
Old 02-05-08, 04:28 PM   #4
Tiger 55
So, notwithstanding sv650k4's kind offer, does anybody actually know the answer to the original question?
Old 02-05-08, 05:03 PM   #5
independentphoto
Did you try Triumph mate? When we visited them in September, the fella reckoned that they'd only just started running out of spares for VERY early models, and that they had just about anything else.....
...think that includes downpipes.
Garry
Old 03-05-08, 07:56 AM   #6
Tiger 55
No. I'm trying not to spend 30 quid on a 10w Triumph part if the 5 quid 21w part from my FLAPS will work just as well.
And leave it about the downpipes!
Old 03-05-08, 12:50 PM   #7
silent11
try any motor spares place as some cars use same relays etc thats where i got my 2pin relay from and there like ?4
most shops do them
Old 17-01-09, 04:50 PM   #8
Dave20046
Dave20046's Avatar
*******thread revival ********
Could someone just tell me (not worth starting a new thread) where the indicator relay is on a curvy and (could answer this myself when I look at it) is it 2 or 3 pin?
cheers
Old 17-01-09, 08:32 PM   #9
It's on the tray on top of the battery, and is bizarrely built into part of the starter lockout system, to use a standard relay you'll need to pull the relevant connectors out of the relay connector and arrange to connect them to your new flasher.
Old 18-01-09, 11:15 AM   #10
Bill.Cross
I'm not absolutely certain about this but my guess is that the wattage rating of the relay just tells you how much power it is capable of passing. My thinking is that if you ask a 10 watt relay to pass 20 watts it will burn out but if you use a 20 watt relay for 10 watts you are just using a more costly and bigger peice of kit than you need but it will still work. It's just a switch.
I think.
Low voltage relays DarrenSV650S Bikes - Talk & Issues 21 16-03-09 09:16 PM
Relays mattc SV Talk, Tuning & Tweaking 2 24-09-08 05:53 PM
LED Flash rate relays... DF! SV Talk, Tuning & Tweaking 4 17-09-08 06:47 AM
Indicator Q Davido Bikes - Talk & Issues 9 16-01-07 09:43 PM
indicator? kwak zzr Stuff Wanted 3 03-12-06 09:26 AM
