Old 02-05-08, 08:18 AM   #1
Baph
Default Tech question... LCD TV woes
Hmm, strange one this.
Last night, my Phillips FlatTV (forget the model number, but I'm pretty sure at this point it's irrelevant) was working fine.
It was turned off softly (power switch on side), left on at the wall socket as we always do.
This morning, turn it on, and there's sound, but the display isn't quite right. There's vertical stripes down across the entire width, each maybe 2-3 pixels wide. These change colour whenever the picture that should be on the TV changes. There's also approx 4-5 horizontal lines that are about 1 pixel wide, randomly spread out down the height of the screen.
So far, my thoughts are incorrect voltage being supplied to the LCD controller (maybe a blown capacitor in the PSU), or the screen needs re-torquing. Both are jobs I should be able to sort out, thankfully.
Ideas anyone? (Queue K "hit it with a hammer").
Old 02-05-08, 08:31 AM   #2
454697819
Default Re: Tech question... LCD TV woes
il skip the technical description ...
hit it with a bigger hammer than k's....
hth
seriously though is it not under warrenty?
Old 02-05-08, 08:37 AM   #3
Baph
Nope, t'is 3years old and didn't take out a a warranty longer than the legal default (1 year).
That's why I'm quite happy to attack it with a screwdriver & soldering iron.
Old 02-05-08, 08:39 AM   #4
gettin2dizzy
I had a TV this happened to, it was sent back and deemed broken so they offered a replacement (out of warranty). I'd chase it up with Philips, even out of warranty an LCD should last longer.
Old 02-05-08, 08:44 AM   #5
Baph
Hmm. Interesting. I'm in two minds about that...
On the one hand, it's not under warranty, so I wouldn't expect them to give a damn. I'm also fairly confident that I can fix it (if it's the causes that I mentionned). Also, it was the last of the line from the shop, and I got a discount for that, and the fact it was out on display in the shop.
On the other hand, you don't get if you don't ask...
Did you have to pay anything to get them to look at it, or indeed pay anything towards the replacement?
Old 02-05-08, 08:45 AM   #6
Scoobs
Philips are ******s. I would never buy another Philips set. I had one go after 3 years and they were totally disinterested. I know it's out of warranty, but 3 years??? When I was little, some time ago, TV's used to last forever.
Old 02-05-08, 08:47 AM   #7
Baph
Hmmm, those would be CRT TVs. I'd argue they don't last forever, having seen many many more failures with CRTs than I have with LCD/Plasma.
Old 02-05-08, 08:50 AM   #8
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
have you tried turning it off and on again? no seriously...
Switch it off at the wall, unplug it for a minute or two, then plug it back in, leave it for a minute or two then switch it on
Don't laugh, this has worked for me when my Sky+ box had a brain fade...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 02-05-08, 08:52 AM   #9
Baph
Yup. Also tried soft factory reset (press & hold power button). In that case, the TV came on, went off, then the power light started flashing (so I knew it'd done it's stuff).
Still the same.
Old 02-05-08, 08:58 AM   #10
Scoobs
Are all your scarts / leads inserted properly. I've had a scart lead come loose and had sound but no picture.
Question for Dad... Triumph 955i tech ThEGr33k Bikes - Talk & Issues 6 22-02-09 01:21 PM
Hi and Tech question Georgio Bikes - Talk & Issues 6 05-09-07 03:40 PM
Top Box Woes.... lynw Bikes - Talk & Issues 12 12-05-07 06:47 PM
Tech Question Moo Idle Banter 2 07-02-07 02:37 PM
Bar-end woes Mark_h SV Talk, Tuning & Tweaking 5 08-01-07 12:07 PM
