Old 09-05-08, 02:26 AM   #1
Zubanoid
Default Handling issues - slight wobble - stability
I have just bought a secondhand sv650 2004 model. I am a fairly new rider also but I tried riding some friends bikes and it seems the hadling on my bike is really different. The other bikes I rode were a Honda VTR1000 SP1 and a Honda VFR400 - both these bikes felt a lot more stable than mine ie firm on the road, leaning into/out of corners was easier etc. Then I jump back on mine and it feels wobbly and a bit 'loose'. My friend who ownes the SP rode my bike and said the same.
I wanted to ask anyone's opinion on the handling? Is it just me or does anyone else think the same?
Old 09-05-08, 03:36 AM   #2
Ratty
Ratty's Avatar
Default Re: Handling issues - slight wobble - stability
SV handling should be great on your smooth roads.
Have you checked all the obvious stuff ?
Tyre pressures, tyre condition, steering bearings, wheel bearings, wheel alignment, engine mount nut / bolt torque (especially the nut behind the gear linkage) and checked for crash damage?
Any of these can give you the feeling you describe
Alan
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 09-05-08, 06:23 AM   #3
mister c
mister c's Avatar
I agree, my first SV handled brilliantly, it could be chucked around with confidence, but this one doesnt feel as stable. I have checked tyre pressures etc & the only thing I can put it down to is the tyres themselves.
They were brand new Bridgestones which I havent ridden on before, so it could be that. I also dropped the preload on the rear shock which helped a little, so you could try that.
Old 09-05-08, 07:08 AM   #4
G
Suspensino set up for your weight, when I first got mine the factory setting were in place, so I adjusted the forks and rear shock and its much more stable now, it used to wallow and bounce around corners so to speak
Old 09-05-08, 07:11 AM   #5
Grinch
I would check the tyres and rear spring if I was you, see if the air in them is correct and that the spring is not to hard or to soft. Depending on your miles the front forks might need the oil changed, but I would be looking at the simple stuff first.
New rear tyre but same old one on front - any potential handling issues? Paul the 6th Bikes - Talk & Issues 18 24-11-08 05:04 PM
Had my 1st wobble last night Nobbylad Bikes - Talk & Issues 11 02-10-08 03:39 PM
V Strom Handling Issues ScatmanJack Bikes - Talk & Issues 10 01-10-08 06:40 AM
Front end wobble SV andy SV Talk, Tuning & Tweaking 8 26-06-07 07:58 PM
GSXR Front End Conversion Handling Issues Mesomorphman SV Talk, Tuning & Tweaking 8 10-09-06 01:46 AM
