Old 11-05-08, 08:58 PM   #1
Girth
Default I'm Horny....
Want to get rid of that scooter/taxi sound of a horn on the SV.
Been briefly browsing for the Stebel Magnum, i want something loud and "quality" sounding and most of all something easy to fit
What did you recommend changing it for?
Old 11-05-08, 09:03 PM   #2
Baph
Default Re: I'm Horny....
Now then, horns eh?
The Stebel Magnum is the one I opted for. It you want to be cheeky, it's a direct replacement for the stock horn (just cut the stock connector in half).
I even helped fit one at AR07 (OK, I tell a lie, I drunk beer & he fitted it to his own bike...).
I decided that a single Stebel Magnum wasn't loud enough (135dbA IIRC). So I added another. This wasn't loud enough either, so I added some marine air horns.
It's starting to sound quiet again... or is that my hearing that's going?
Old 11-05-08, 09:51 PM   #3
Fitted a pair of stebel magnums to melodys bike today. It's fkin loud and fairly easy to do.
Old 11-05-08, 10:39 PM   #4
TightRS
TightRS's Avatar
?13.99 from Halfrauds. I used the two metal brackets that came in the pack and wedged them behind the radiator cover. It has a nice rounded 'parp' sound (model TM80/1) and works well on drivers and sheep
As mentioned I had to split the connector and some sheath with wire cutters, it's very short and limits the horn placement options. As an aside I found the horn will screw directly into the radiator hole if needed, but might help bend it if you drop the bike.
SV650S K5
GSX-R Shock, R6 Throttle, Oxford Hot Grips, R&G Crash Guards, Hugger, Fender Extender, Radiator Cover, Mirror Extenders, Stebel Magnum Horn, DL Handguards, Philips X-treme +80%, Denso Iridium Plugs.
TightRS is offline   Reply With Quote
Old 11-05-08, 10:40 PM   #5
If you use 2 horns then you need a relay IMO
Old 11-05-08, 11:24 PM   #6
markmoto
Stebel nautilus compact are good if a little large i bought one for my bike but it got fitted to my van sounds like a locomotive horn , a cheap easy fix and a big improvement is to fit a car horn most cars have decent horns nowadays ive got a spare alfa horn if you want it.
Old 12-05-08, 04:51 PM   #7
sv-robo
I'm always horny.......must be the hot weather,lol.
Old 12-05-08, 05:48 PM   #8
Girth
Ah cheers, how easy is it to fit?
Old 12-05-08, 07:08 PM   #9
markmoto
yeah easy peasy just gota make a little bracket up and it will sit just on top of the radiator hose on the right hand side behind the radiator.
Old 12-05-08, 08:51 PM   #10
Girth
Sound like a normal car horn being an alfa one?
Talking Horny squirrel_hunter SV Talk, Tuning & Tweaking 18 23-06-05 05:23 PM
