Hopefully going to buy my first SV650 tommorow, going to look at it in the evening. What should I look out for? It's a K1, so any common problems with them &/or any other hints and tips would be much appreciated.
Cheers ![]() |
Handlebars These are easy to bend and can be costly to replace. Are both bars even and straight? Bent Forks & Fork Play Look down the length of the forks a check for any bends which may have been caused by a collision. Hold the front wheel between your knees and twist the bars - Is there any play? Levers and pedals Check all the levers and pedals to ensure that they are all firmly attached. Look for excessive wear which may indicate high mileage (compare with recorded mileage). Headrace Lift the front wheel by getting someone to push down on the seat (on centre stand) gently turn the bars from the left to right and back. If it feels notchy when it passes centre, then the headrace needs replacing. If it's stiff it may just need adjusting. Exhaust & Mountings In a crash the exhaust can sometime get pushed into the frame. Is the exhaust or frame bent? Also check the joins by placing your hand near them while the engine is running . Is gas escaping? A new exhaust could easily cost £500. Wheels & Brakes Lift the front wheel and make sure it spins freely. Apply the front brake, release and re-check the brakes (a few times). Do the same to the rear. Do the wheels bind? If so you could be looking at replacement pads, bearing or callipers. If available lay a straight edge along the sides of the front and rear wheel and check that they are aligned. Also Look for dents in the rim which may have been caused from curbing at speed. Wheel dents can be corrected (see links), but a new wheel may cost over £300. Raced and abused Check the wheel rims, shocks and forks for excessive wear. thrashing or racing a bike will eat tyres and suspension very quickly, so if the wear looks out of place with the immaculate paint work, then the bike may have had a hard life. Electrics & Unusual wiring Check all the lights and switches work properly, don't forget to give them a tap with your hand to check there are no lose wires. Extra switches or fans, can sometime point to electrical or cooling problems. As a minimum check the reason behind any unusual switches or wiring. Frame & Alignment There are a number of ways to check the frame and wheel alignment, but most require a long plank or similar. However for bikes fitted with front and rear disc brakes a simple right angled spirit level is all you need. Position the bike so that the rear disc is level, then position the front disc to be the same. Now check handle bars, if they are not aligned, there can be several reasons: the front and rear wheels are miss aligned, the frame or forks are damaged, the front or rear discs are warped, the swing arm is damaged. Rust If the bike's been out in the wet, then rust is a possibility, you need to check for rust that's just surface and can be cleaned off or more serious structural rust. If it can be rubbed off with a wet finger then a good cleaner should remove most of it. If it crumbles when you poke it - walk away. Wear Motorcycle parts are fairly expensive and can be fiddly to replace, particularly on faired bikes. A recent Bike magazine calaculated that a bike costing £6000 new, would run to £25,000 if it was build from parts. The costs can really pile up if you need to replace mechanical items. Motorcycles must have a minimum or 1 mm tread across 3/4 of the width of the tyre and usually cost over £100 per pair Are the tyres in poor condition? Also check If the chain is stretched or has tight spots, If the brakes are worn or discs scored. Each item could cost a £100+ to fix. Check the suspension Although Tax is just a maximum of £65 on motorcycles, its worth checking how much is left.
hi......... have a search, but i think this covers most things
Originally Posted by fizzwheel Hi and welcome 1. Look at the front forks are they corroded and chipped, This is pretty common on a high milleage SV thats been used in all weathers. Its a good indication of what the bikes been used for and also if the milleage is correct. i.e if the forks are chipped and manky but the milleage on the bike is low then start asking questions. Same goes for the handlebars and footpegs. 2. Have a look at the disks and pads. What condition are they in. SV's are known for the brakes sticking on if its not been looked after. Again this is especially relevant if its been used through winter and neglected. 3. Look at the chain and sprocket and the tyres. how much life do they have left in them, and slack worn chain with hooked teeth on the sprocket mean that its going to want changing soon. 3. Electrics, some people including me have had trouble with blown fuses caused by the wiring loom rubbing on the tank. So ask about that to. 4. If its a private sale, if you can get a sneaky peak in the owners garage, have a look for stuff like, paddock stands, a good set of tools, cleaning products, chain lube etc on the shelf, It'll give you an idea of how the current owner looks after the bike. 5. Sometimes if the bikes ridden in heavy rain water gets into the front spark plug hole and then it'll drop down onto one cylinder and run intermitantly between one two cylinders which isnt fun. A fenda extenda will sort this or some silicone grease on the front HT lead will also do the trick, have a search for the subject its been covered loads of times and its fairly common. Ask the owner if they have had trouble with the bike in the wet, its not a huge problem and its easy to sort. Dont be put off by high milleage as long as you can see that the servicing has been done, either by stamps in the service manual or receipts for parts used. A high milleage bike thats been ridden is better than a low milleage bike thats been stood for ages and has got all seized up. Use things like worn tyres, chain and sprocket as bargaining tools to get the price down. Make sure you do a HPI check to make sure that theres no outstanding finance or the bike hasnt been involved in a accident at some point in its life. Remember that non standard parts dont increase the value of the bike. So dont let the bling bits distract you from the of the bike, better IMHO to buy a mint standard bike than sh*tter with loads of aftermarket parts bolted onto it. Things like a hugger, a scotoiler are sensible modifications though as is a race can but only if you like the sound / look of it. If you're not sure, Walk away from the bike, or take somebody with you who does know what they are looking at. Make sure you look at plenty of bikes and never buy the first one you look at. As for price, it really depends on what you are looking for. 99 - 02 year model bikes tend to be in the £1500 to £2500 mark and 03 Onwards Bike look like they go from anywhere around £2750 upwards. Depends what you want and how much you want to spend. HTH |
Yeah watch out for that one I'm selling in a couple of weeks, it's a right bargain...
what to look out for on 2nd hand curvy SV's | RPC_SV | SV Talk, Tuning & Tweaking | 14 | 20-06-08 07:34 PM |
left hand lower and left hand tail piece | malks | Stuff Wanted | 2 | 02-06-08 09:56 PM |
How many SV's are actually on here then? | Brettus | Bikes - Talk & Issues | 26 | 10-01-08 10:59 PM |
Info wanted on buying a 2nd hand SV650S | Stradders | SV Talk, Tuning & Tweaking | 14 | 20-07-07 06:42 PM |
