Old 17-05-08, 09:32 PM   #1
GWormald
Default Overheating exhaust
I have a SV650 K2 with 6000 miles on the clock. Been stood for about 12 months and was started up every 3 months or so. I've just noticed that when I've started it up recently, the front exhaust pipe is glowing red hot after about 2 minutes (burning low fairing) It starts up OK, ticks over OK and seems to run OK. The temp warning light doesn't come on, but it does smell hot.
What could be the cause of the overheating exhaust, and what is the solution.
Godfrey
Old 17-05-08, 09:33 PM   #2
Default Re: Overheating exhaust
Lean running or bad carb balance IMO
Old 17-05-08, 09:41 PM   #3
embee
embee's Avatar
I think you'll find they all tend to do that.
Certainly mine will start to look dull red if I hold the revs up around 3000 and it's in the garage out of daylight (doors open folks!).
I suggest there's probably not much wrong, though some fresh fuel wouldn't go amiss by now!
Old 17-05-08, 10:49 PM   #4
TSM
The Sick Man
TSM's Avatar
if the choke is on for too long then they will start to glow
Intermittent overheating SV650S K5 hutchy SV Talk, Tuning & Tweaking 2 13-09-08 11:58 AM
Am i overheating? speedyjanner SV Talk, Tuning & Tweaking 12 26-06-08 07:24 AM
rear disc overheating Nitzer SV Talk, Tuning & Tweaking 6 27-02-06 12:18 AM
Engine Temp OK or overheating???? Khewett SV Talk, Tuning & Tweaking 17 06-09-05 06:35 PM
