Old 18-05-08, 08:53 PM   #1
Razor
Default Change rod woes.
I took my change rod off for measuring yesterday, with view to having a new one made. Unfortunately I have left it somewhere and it's now disappeared. i suspect it somehow ended up in with some rubbish that was taken to the dump but nobody will own up to seeing the "bent, rusted piece of metal" that I'm sure i left on the dining room table...
So what size is the change rod for a 2000 Sv650S?
Anybody?
Old 18-05-08, 10:02 PM   #2
21QUEST
21QUEST's Avatar
Default Re: Change rod woes...
Total Length=176mm
Threaded section at both ends=12.5mm
Diametre of rod=6mm
Ben
Nemo me impune lacessit.
Old 18-05-08, 10:37 PM   #3
LH thread on one end is it not?
Old 19-05-08, 10:47 AM   #4
Razor
Originally Posted by 21QUEST View Post
Total Length=176mm
Diametre of rod=6mm
Ben
Thanx Ben!
I didn't think so...
Old 19-05-08, 10:59 AM   #5
Scoobs
It is. RH thread one end LH on the other. It wouldn't adjust otherwise.
Old 19-05-08, 11:08 AM   #6
Al_Sweetman
+1 - as you unscrew one end it screws in the other end, thus keeping it secure and providing a different to the angle whilst keeping the distance universal.
Old 19-05-08, 11:22 AM   #7
Razor
If it was LH thread one end and RH thread the other, when you unscrew one side the other would also unscrew...
Old 19-05-08, 12:00 PM   #8
Dangerous Dave
Yeap, it is on both of mine anyway. Try somewhere like Pro Bolt if you are looking for an aftermarket alloy one.
Old 19-05-08, 12:36 PM   #9
Scoobs
Correct! That is how it adjusts. Sheesh!
Old 19-05-08, 01:21 PM   #10
Stu
Trinity
Stu's Avatar
Yup so you can make it longer or shorter.
EU Woes...... SoulKiss Idle Banter 0 20-09-07 11:43 AM
Top Box Woes.... lynw Bikes - Talk & Issues 12 12-05-07 06:47 PM
Bar-end woes Mark_h SV Talk, Tuning & Tweaking 5 08-01-07 12:07 PM
Change in weather= Change in diet Dicky Ticker Idle Banter 5 15-08-06 06:51 PM
