Old 26-05-08, 06:26 PM   #1
Lucas
Default Fork oil change
Silly question time
My forks are bottoming out too often (london roads )
Q1 - I want to fix it on the cheap by just changing to heavier oil, 15W with OEM stock springs, I'm 11 st. What do you guys reckon?
Q2 - To change the oil, the menu instruction is to take the whole fork out and turn it upside down... but I also heard that there is a screw under the fork that can be used to drain the oil with forks in place, is this the case for a year 99 curvy? Has anyone done this already?
cheers
Old 26-05-08, 06:35 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: Fork oil change
Originally Posted by Lucas View Post
Silly question time
cheers
There is no drain screw, the bolt at the bottom of the fork holds the damper rod in place and also stops the top part of the fork from seperating from the bottom part.
Old 26-05-08, 06:38 PM   #3
Sideshow#36
Get your nose plugs out... because that stuff stinks!!! Especially if it hasnt been changed for a few years.
Old 26-05-08, 06:40 PM   #4
embee
embee's Avatar
I have a curvey. Best way is to remove each fork leg and turn it upside down to drain. Remember to loosen the top cap before undoing the yoke clamps.
I understand the desire to minimise cost, I went the route of trying slightly heavier oil first and washers to adjust the ride height or "static-sag" (cheapest option).
However I finally did get round to fitting stiffer springs to suit my weight and boy what an improvement. If you can stretch to it, new springs and normal weight oil is a much better solution, trust me (T-shirt for sale). I think Hagon are about the best value for springs at the moment. I'd suggets at your weight about 0.8kg/mm would be ideal, 0.85 will do and wouldn't be too stiff. (standard curvey is 0.709kg/mm, yours will probably have relaxed a bit by now too). Somewhere round £70 should do it, springs and oil, I believe.
Old 26-05-08, 06:41 PM   #5
Silly question time
S'OK, I'm getting used to it.
I'm not surprised.
Well it's hardly 'on the cheap', it's the obvious thing to do - many have.
Correct, it's the only way to do it properly - despite what you may have heard from some sources.
See what I mean? There is NO drain screw, that bolt holds the fork together.
No.
Sadly yes, and it's still not a drain screw.
cheers
You're welcome
Fork Oil Change Old Git SV Talk, Tuning & Tweaking 50 16-06-09 10:50 PM
Fork change (not the same as other threads) ThEGr33k SV Talk, Tuning & Tweaking 7 16-06-07 03:44 PM
easy fork oil change johnnyrod SV Talk, Tuning & Tweaking 7 24-05-05 02:40 PM
FORK OIL CHANGE - ADVICE Mr Sensible SV Talk, Tuning & Tweaking 28 04-02-05 08:30 PM
Front Fork Oil Change Tris SV Talk, Tuning & Tweaking 8 20-12-04 05:21 PM
