Old 27-05-08, 06:38 PM   #1
Default Changing valve stem
Right then... I had a random flat on the way home last night, but the tyre holds air, which is making me suspect the valve... It's a pretty old one too. Now, last time I changed a valve I had a bolt-in one to fit, which was dead easy. But all the ones I have now are of the large rubber variety, much like this:
http://ourworld.compuserve.com/homep...rtyrevalve.gif
So... Never fitted one of these, haven't a clue what I'm doing. I'm assuming it fits from the inside, so that air pressure forces it in not out, is there any knack to fitting or is it just force?
Old 27-05-08, 07:07 PM   #2
mattc
Default Re: Changing valve stem
Hi,
There's a simple tool for pulling them in (like this http://cgi.ebay.co.uk/KART-WHEEL-VAL...tegoryZ12230 )
And it's just a case of pulling through and making sure it seats.
Old 27-05-08, 09:17 PM   #3
dirtydog
Knob faced knobster
dirtydog's Avatar
But if you haven't got the little tool thing, which i haven't you cna use some pliers if you're carefull.
All i've done on the past couple i've done is lube it up with some soapy water, screw the cap on and use the pliers (on the cap) to pull it through, it'll pull through easily
2011 Speed Triple 1050
Old 27-05-08, 09:19 PM   #4
Looks like quite a handy tool that, at the price I've just ordered one, cheers!
Steering stem cammy SV Talk, Tuning & Tweaking 3 30-04-09 06:26 PM
Stem Nuts Bibio Stuff Wanted 4 29-08-08 09:08 PM
Steering stem removal Torn-Thorax SV Talk, Tuning & Tweaking 17 20-09-07 10:12 AM
Valve stem seals svrash SV Talk, Tuning & Tweaking 2 24-01-07 10:07 PM
Steering Head Stem Nut scooby2102 SV Talk, Tuning & Tweaking 0 06-12-06 01:41 PM
