Old 03-06-08, 08:14 PM   #1
mister c
mister c's Avatar
Default Hopefully mine should run better now
Had a few problems with mine this week, but yesterday had an inkling of what it was. Gladly, the sun was shining after work, so i set to getting the tank & carbs off.
The carbs were full of water as in pic 1
The tank was even worse with nearly 200ml of water sitting in the bottom of it.
I was correct that the hole in the top of the tank to get rid of water was completely blocked with crud, so the water went straight into the tank itself. I have only run it in the yard, so I hope that it will be ok now.
Old 03-06-08, 08:38 PM   #2
Default Re: Hopefully mine should run better now
it has to be better now, good job matey
Old 03-06-08, 09:23 PM   #3
Whoa lovely.
Old 04-06-08, 05:10 AM   #4
mister c
mister c's Avatar
Hoping it gets me to work this morning, if not it's a long walk
Old 04-06-08, 06:48 AM   #5
Glad you got it fixed, this problem hasn't been as common recently, but was frequently reported some time ago.
I've seen a few damaged tanks too - rusted either in the drain itself, (the blockage allows water to sit in the pipe), or water sitting in the tank rusts it through at the rear on the left just by the seat.
Old 04-06-08, 10:14 AM   #6
mister c
mister c's Avatar
Couple of chugs 1st off, but is running as sweet as a nut again. I'm like a pig in muck, dont like riding IL4s keep looking for 7th & 8th gear all the time
The amount of prodding withy a piece of wire was amazing, but the muck eventually shifted.
Old 04-06-08, 10:19 AM   #7
Just been and blasted the drain's on mine out with WD and the air line now the recent "my tanks knackered" threads reminded me...
Old 04-06-08, 10:33 AM   #8
dyzio
dyzio's Avatar
where is this located?
Old 04-06-08, 10:34 AM   #9
In the filler cap
Old 04-06-08, 01:09 PM   #10
mister c
mister c's Avatar
Here you go. The hole goes from here to the rear of the tank. Make sure it's clear, or you will end up with the same problem as me.
She is FIERCE and she is all MINE!!! Ruthja2801 Idle Banter 80 02-03-09 12:05 AM
will these rearsets fit mine? Toriiii33 SV Talk, Tuning & Tweaking 8 27-02-09 04:57 PM
not mine but check this out richie95 For Sale - SV's and SV related items 13 09-07-08 11:40 PM
ITS MINE, ALL MINE macdo Pennine Massive 12 28-08-05 07:26 PM
Mine All Mine!! - Finally 454697819 Bikes - Talk & Issues 14 27-12-04 11:12 AM
