Old 10-06-08, 10:51 PM   #1
Blue_SV650S
Default Innertube - punctures
Ok, can anyone see a problem with using an innertube on an SV on a tubeless tyre if/when it has picked up a puncture ... obviously using common sense that the puncture was irritating small nail say, not a bit of scaffold pole stuck out!
I mean, I guess the tube should form/deform to the insides of the tyre and press it on the rim just as if it was plain air surely???
Old 11-06-08, 11:19 AM   #2
Stu
Trinity
Stu's Avatar
Default Re: Innertube - punctures
I believe Rictus uses an inner tube & normal SV type tubless tyres on his spoked wheels. So can't see it being a problem just overkill compared with a puncture repair. But I guess you have a free inner tube
Old 11-06-08, 12:56 PM   #3
Blue_SV650S
Yes, I now have an inner tube
The beauty of using the inner tube is not only is it free to fix and have minimal chance of failure, that if you pick up further punctures, you can just fix the tube with a normal pushbike repair kit (I presume)
Old 11-06-08, 03:09 PM   #4
Stu
Trinity
Stu's Avatar
You say that as if motorcycle repair kits are difficult
Old 11-06-08, 04:17 PM   #5
Blue_SV650S
It is not difficult at all, you just have to pay a professional to do it*!!
*i.e. a 'mushroom' type repair is the only proper repair and what the pros use ... to my mind, reaming a f-ing great hole in a tyre and bunging in a bit of rubber from the outside, isn't a satisfactory long-term repair
Old 11-06-08, 04:25 PM   #6
SoulKiss
SoulKiss's Avatar
Erm the pros do it by cleaning the inside of the tyre in the area of the hole, then gluing in a patch which has a stalk on it (hence called a mushroom) which goes to fill any hole in the tread area, this is then trimmed off.
The ream a hole in it and stuff from the outside repairs are only ever temp roadside, get you to a proper place fixes.
Old 11-06-08, 04:31 PM   #7
Blue_SV650S
Er ... that is what I said isn't it?!!?
Old 11-06-08, 04:37 PM   #8
SoulKiss
SoulKiss's Avatar
Erm, maybe
look, its the goodyear blimp !!!!!
DOH!!!!
Note to self, dont skim read the .org while debugging LDAP problems.....
Old 11-06-08, 05:47 PM   #9
Stu
Trinity
Stu's Avatar
Erm no, it's good enough for me, but I'm not forcing it on anyone else
(crafty plugger)
Old 11-06-08, 06:40 PM   #10
muffles
Blue, you have the tools to fit your own tyres, can't you just do a 'proper' puncture repair?
Punctures! *RAGE* injury_ian Bikes - Talk & Issues 30 20-11-08 05:29 PM
Mother of all punctures! Sideshow#36 Bikes - Talk & Issues 9 22-09-08 07:00 AM
2 punctures in 2 days mister c Bikes - Talk & Issues 1 17-08-07 10:20 AM
punctures and the AA busasean Idle Banter 2 02-02-07 01:55 PM
&$&%^&$£ Punctures Iansv The Essex Lounge 3 19-04-06 06:49 PM
