Old 19-06-08, 07:36 PM   #1
butterick99
Default Rectifer and Regulator
This might sound like a stupid question but does anybody know where the rectifer/regualtor is on my SV650S 99 curvy and if its a big job to change it because from what im reding it sounds like this is the problem..... if its under warranty will they do that for me..... is that a warranty item etc
D
Old 19-06-08, 08:01 PM   #2
Default Re: Rectifer and Regulator
It's under the tail pod on the right hand side and it's less than 15 minutes to swap. Check the wiring loom for chaffing too and add some spiraband as preventative maintenence.
Have you checked the charging circuit then?
Old 19-06-08, 08:40 PM   #3
sv650k4
yes as said under the tail pod.
Old 19-06-08, 08:43 PM   #4
butterick99
Ok... i havent check the circuit... how would i go bout doing this... to be honest i dont have the tools really..... thats the problem i have.... i would be happy to try everything but tools are the problem.....
Old 20-06-08, 08:18 AM   #5
JamesMio
I think a cheap wee Multi-Meter would do the job.
As far as changing the regulator/rectifier goes, it's not a difficult job - literally a case of a few bolts to remove the rear plastics, grab rail and pop out the pillion seat lock cable, and the regulator's as others have said bolted onto the right hand side of the frame under the rear pod. Two bolts and it's off.
PS - do you have a Haynes manual? Worth their weight in gold for stuff like this...
"That **** on the push-bike."
Creatomatic
Old 20-06-08, 09:22 AM   #6
butterick99
Yeh i have a haynes manual hiowever i find it difficult to follow sometimes lol well i did when i changed the spark plugs.... but when im checking the connection how will i know if something is wrong
Old 20-06-08, 09:29 AM   #7
Viney
Its a simple check.
Take the main seat off (Remove the 4mm allen bolts in the small black things either side under the seat) then the 2 allen bolts holding the main seat on (5 or 6mm) There you will find the battery if you havent already.
Get a Multimeter of some sorts that will read DC volts and amps
Start the bike and put the multimeter on the terminals, it should read around 13.5-14.5 volts when running, and around 12.5 volt with the engine off.
Thats the basic test. If its higher when the bike is running then the the reg is kaput, if the voltage is lower when the engine is off, then the battery is kaput.
There are more tests in the Haynes.
Old 20-06-08, 10:05 AM   #8
Yup also try rev it up to 5k with headlights on and see hwat voltage you get.
Old 20-06-08, 10:28 AM   #9
butterick99
Ok at the moment the battery is dead as i havent charged it since it went dead on me again...... once charged the bike should fire up..... where can i get a meter reader from...... once i have this meter reader then test the battery with it running and with it off..... if the battery seems fine then what should my next step be!
Thanks for your guidance guys.....
Old 20-06-08, 10:30 AM   #10
JamesMio
Maplin, Halfords or anywhere that sells car / electrical stuff really, in fact I wouldn't be suprised if Tesco are selling them now.
Creatomatic
Wiring in A Rectifer...From a Different Bike 21QUEST SV Talk, Tuning & Tweaking 14 16-04-09 08:23 PM
Where is the regulator philbert SV Talk, Tuning & Tweaking 7 26-09-08 05:21 PM
The Correct Regulator/Rectifer butterick99 SV Talk, Tuning & Tweaking 11 08-07-08 10:50 AM
It must be the regulator... NadineDieBiene SV Talk, Tuning & Tweaking 7 05-11-07 01:06 PM
Regulator/Rectifier Steve T SV Talk, Tuning & Tweaking 3 10-10-04 10:34 PM
