Old 25-06-08, 11:00 AM   #1
TheShadow
Default Wanted : Reg/Rectifier
I am after a Reg/Rectifier that will be compatible with a 2000 curvey.
I want one from a known working bike.
Cheers.
Old 08-07-08, 09:39 AM   #2
TheShadow
Default Re: Wanted : Reg/Rectifier
Bump.
I have a 2002> regulator but it has the wrong connector still in need of a 2000 rectifier!
Old 08-07-08, 10:22 AM   #3
hovis
see for sale section
not sure if its the right one though?
Old 08-07-08, 10:51 AM   #4
Baph
Cheshire Motorcycle Salvage have a couple.
01625 502372
Old 08-07-08, 08:09 PM   #5
mac
Dude - i have a working one.
Will fish it out tonight.
Make me an offer.
Old 09-07-08, 03:10 PM   #6
Can you solder? It'd dead easy to swap the plugs between 02 and earlier, they're essentially the same unit with different plugs.
Old 09-07-08, 09:05 PM   #7
TheShadow
The problem northy is the the rec/ regulator is possibly working and I don’t want to cut the plug on it just yet.
The symptoms are the charging circuit charges when the headlights are turned off but as soon as you turn them on the charging circuit fails and drains the battery.
The second reason is I can get access to the connector to swap the regulator over but not to directly wire one in I intend to plug a working unit in and if it solves the problem drill the screw out and install it properly if not I will be looking for some help
http://forums.sv650.org/showthread.php?t=113180
MAC you have PM
Old 14-07-08, 06:42 PM   #8
TheShadow
I now have one for my bike just waiting on it being delivered.
Still selling a rectifier/regulator for a K2.
http://forums.sv650.org/showthread.php?t=113816
Wanted Regulator rectifier Pam Stuff Wanted 0 07-02-09 06:20 PM
Regulator / Rectifier wanted! mikeSV Stuff Wanted 5 05-08-08 01:03 PM
Wanted - Regulator/Rectifier for SV650S 99-03 ricky_t Stuff Wanted 0 24-06-08 08:30 PM
rectifier hovis Stuff Wanted 2 23-09-06 09:25 AM
1999 SV650 rectifier wanted. Layzeeness Stuff Wanted 0 01-07-06 02:35 PM
