Old 29-06-08, 07:49 AM   #1
Bad Intentionz
Question GSXR 600 SRAD Shock Fitting?
Just a few questions. I recently got a SRAD 600 shock off a friend who didn't get round for using it for one of his projects and need to find out the following:
Can I use the original bolts from the SV shock?
How much cutting away will the battery box need and does the tank hinge need any cutting?
The shock is 38mm longer than standard. How will that compare to say a 12mm drop at the front. Will it be more or less responsive?
How do you change the spring?
Also if anyone has fitted an SRAD shock to their curvey and could help out with basic compression and tension settings that they found worked well please let me know. Any help will be appreciated
Hopefully fitting it this afternoon
Old 29-06-08, 11:16 AM   #2
Default Re: GSXR 600 SRAD Shock Fitting???
38mm longer shock will give you a massive increase in ride height, I used the SRAD750 shock which is shorter. It'll be twitchy!
The spring's quite soft, I had to use all the preload adjustment to get anything like right sag. Ended up with rebound at SRAD stock setting and compression something like 1/4 turn softer
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
SRAD rear shock fitting yorkie_chris SV Talk, Tuning & Tweaking 2 07-04-08 09:11 PM
fitting a sv rear to a gsxr srad sv650nutter149 SV Talk, Tuning & Tweaking 18 08-01-08 01:00 AM
Fitting a GSXR Shock The Wolf SV Talk, Tuning & Tweaking 32 27-06-05 04:57 PM
SRAD or 636 shock Dan_SV SV Talk, Tuning & Tweaking 21 29-01-05 10:16 AM
