Old 29-06-08, 03:08 PM   #1
Tris
Default Turning Bike around in the garage
Whats the techinque to spin the bike around on the side stand?
I tried and all the straining left me weak at the knees and the bike exactly where it started
Old 29-06-08, 03:11 PM   #2
Woz
Default Re: Turning Bike around in the garage
Stand on the left side of the bike and grab the lefr handlebar and the rear subframe on the right hand side of the bike (reach over the top). Pull towards you and the bike wheel should come off the floor. Try to balance the bike on the stand with the front wheel a little higher than the bike so it can't fall off the stand. Once you have it balanced, it is very easy to spin around.
Old 29-06-08, 03:15 PM   #3
Tris
Cheers Woz
Does it mater which way you turn - ie do you pull the handle bar to turn??
Old 29-06-08, 03:17 PM   #4
Woz
Yeah, pull the bars and spin it anticlockwise.
Old 29-06-08, 03:18 PM   #5
Tris
OK Ta
I'll go give it a try later. If you hear a crash you'll know I screwed it up
Old 29-06-08, 03:19 PM   #6
I'm not strong enough to do that,and I have a weak vertebrae at the bottom of my spine........however I have a squeeze with my two in my shed and have to regularly lift the rear by the grabrail, and oik em from side to side........gives you BIG biceps!!!!!
Always stand on the sidestand side if you do this
It takes a little more effort, but I have turned my SVs full 360 like this
Old 29-06-08, 10:25 PM   #7
Durbs
You can turn the bike round on the side stand????? Cool, i need to do a 20 point turn every time i get the bike out due to dramatic miscalculations when locating my new shed.
Old 29-06-08, 10:37 PM   #8
My drive is stupidly steep with little access into the garage, I do it every time. Pull the grab rail towards you and push down on it to get both wheels to slide and spin it round, it's easy but lean back.
Do you actually keep your bike in the garage? Magnum Bikes - Talk & Issues 61 11-12-08 05:27 PM
Gizmo for turning a bike in a confined area ? :) Ablazze Ancillaries 20 23-11-07 07:41 AM
Turning the bike around on its side stand swamp Bikes - Talk & Issues 21 07-07-06 02:53 PM
Turning bike in small spaces... Jdubya Bikes - Talk & Issues 30 01-06-06 09:19 PM
The bike garage thing ? The Mass Bikes - Talk & Issues 33 04-02-05 06:44 PM
