Old 05-07-08, 02:09 PM   #1
Baz
Default Front break not lighting break light?
Hello
Just noticed when checking all my lights etc when I pull on the front break the break light dosn't come on. The back is fine just the front thats the problem.
I guess just a relay or something but before I go and start playing around with it thought I would check with you guys.
Any thoughts or ideas where to start?
Old 05-07-08, 03:46 PM   #2
embee
embee's Avatar
Default Re: Front break not lighting break light?
Quite likely it is just the switch at the front brake lever. It is a small rectangular plastic box mounted under the bracket (on a curvey anyway). Can you hear it "click" when you operate the lever?
Mine played up, and I found the contacts had some dirt built up. I cleaned it and covered them in vaseline and it has worked fine since.
Note that they are not intended to come apart for cleaning the contacts inside, but you can get them apart by prising the halves apart at the 3 rivetted plastic pins. Otherwise some switches have vent holes in them, in which case simply squirt it full of contact cleaner or WD40, operate the switch a few dozen times, and allow to drain. If it isn't working already, you can't do any harm!
If all else fails they cost about £7 (I think).
Old 05-07-08, 05:29 PM   #3
Dangerous Dave
Mine played up, and I found the contacts had some dirt built up. I cleaned it and covered them in vaseline and it has worked fine since.(I think).
+ 1
Old 05-07-08, 09:25 PM   #4
Baz
Ok contacts look clean, gave them a spray with contact cleaner anyway but to no effect, the only clicking I can hear is from the break itself not the break leaver.
I have also measured the voltage to make sure it's not a power problem also belled through the conection from the rectangular plastic box mounted under the bracket right through to the conection at the tail both of these seem fine.
Any other ideas?
Old 05-07-08, 09:36 PM   #5
embee
embee's Avatar
If you link the connector wires at the front switch does the brake light come on?
Old 05-07-08, 09:45 PM   #6
Baz
Havn't tried that. I take it what your getting at there is by passing the switch?
Will give it a go, might leave it to tomorrow though, it appers monsoon season just started outside.
Old 07-07-08, 05:17 PM   #7
Baz
Just tried conecting the wires together and the light comes on, I take it the problem is going to be the switch in the break lever? Is this something that can be fixed at home or is it a garage job?
Old 07-07-08, 05:19 PM   #8
Originally Posted by Baz View Post
Hello
Just noticed when checking all my lights etc when I pull on the front brake the break light dosn't come on. The back is fine just the front thats the problem.
HTH
It's the switch that's dodgy then, might as well replace it with a pressure switch banjo bolt, easier when you upgrade something then...
Old 07-07-08, 05:25 PM   #9
Dangerous Dave
More reliable too...
Old 07-07-08, 08:02 PM   #10
embee
embee's Avatar
It'll be the contacts (inside the switch, not the cable conectors).
You have 2 options on this, try to prise the switch apart and clean them up (as described in my first reply), or simply replace the switch. I'd suggest you may as well try the clean up since it's not working anyway so nothing to lose. If it fails just get a new switch, not a huge outlay and only 2 screws. Incidentally other bikes use the same/compatible switch (my Honda has the same thing just with a vent hole modification).
As the others say, the third way is with a pressure switch, but that's another story.
My Curvey's still for sale (break for parts or fit a new front end) jamessunhill For Sale - SV's and SV related items 1 13-08-08 11:56 PM
Break light, by which I mean it's broken, or do I? Perhaps I meant BRAKE. drag SV Talk, Tuning & Tweaking 7 23-08-07 11:22 PM
Should I break my Curvy SV? Mags SV Talk, Tuning & Tweaking 11 13-08-07 07:28 PM
Attempted break in - again! gettin2dizzy Idle Banter 31 26-05-07 10:41 PM
Crash.NET - Stoner makes a break, Capirossi back to the front. NewsBot News 0 20-04-07 08:10 PM
