Old 06-07-08, 02:27 PM   #1
Default orange
Since I moved house I don't get a signal on my phone. It was crap in the old house too but here I can't even send a text unless I hold up the phone to the roof. Its pathetic.
Its on a 18 month contract with orange. Is there any way to cancel it early because its basically unusable ?
Old 06-07-08, 02:46 PM   #2
Shellywoozle
Shellywoozle's Avatar
Default Re: orange
Contact them, when you are able (LOL) I have heard they can boost the signal to your phone but I am not sure.
No point having a phone if you can't use it, sure they can do something to assist you. At the end of the day you pay for a service and if they are unable to provide to where you are then does that make it "not fit for purpose" or summat.
Either that or get a chair on stilts so when you need to use your phone you are higher towards your roof.
Old 06-07-08, 02:50 PM   #3
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: orange
what handset is it? my mum had the same thing only we were both on vodafone and mine was perfect, turned out it was the handset that had a crappy antenna and nothing to do with the reception in the area...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 06-07-08, 02:57 PM   #4
Default Re: orange
It's a samsung G600
Old 06-07-08, 03:00 PM   #5
Shellywoozle
Default Re: orange
It's a samsung G600
Aerial built in the handset.
If it worked before you moved I would say it's a signal issue unless you have dropped ya phone.
Old 06-07-08, 03:19 PM   #6
Default Re: orange
Just phoned them up. "orange cannot guarantee a signal in a building or a moving vehicle."
Only option - Pay up the remaining 9 months of your contract - £225
Old 06-07-08, 05:23 PM   #7
TEC
TEC's Avatar
Default Re: orange
Been able to pick up an Orange signal better than some guys at work on other networks, simialr situation when up in the more remote areas up there
Do you get a good signal outside the house, if so then its the house itself blocking the signal, same thing happens in older houses when people try and use WiFi and the walls block the signal
I am behind you
http://wildwesternadventures.com/
TEC is offline   Reply With Quote
Orange Pay Monthly BanditPat Idle Banter 3 10-05-09 12:21 PM
orange broadband sv_rory Idle Banter 17 19-11-08 09:26 PM
The Orange Box Bluepete Idle Banter 3 29-12-07 05:57 PM
Orange Support Demonz Idle Banter 8 30-09-06 12:44 PM
Orange juice Viney Idle Banter 34 08-08-05 07:26 PM
