Old 07-07-08, 08:56 PM   #1
addicted to rage
Default dam push rod seal
hi lads me chain snapped there the other week broke the push rod on me so i replaced the rod and the seal but the bloddy bike is still ****in oil doin me nut in the push rod is spinnin when engine is runnin but not spinnin in a perfect circle is the a bearing behind the seal r some thing
Old 08-07-08, 08:28 AM   #2
addicted to rage
Default Re: dam push rod seal
had a look this mornin there does appear to be a bearin behind the seal and it looks damaged the centre looks off centre the in gods name do i get that out
Old 09-07-08, 07:44 AM   #3
addicted to rage
bump
Old 09-07-08, 08:08 AM   #4
Spanner Man
Good morning .
It's an engine strip down by the look of it. Bad show!
Cheers.
Spanner Man
Old 09-07-08, 08:45 AM   #5
addicted to rage
Originally Posted by Spanner Man View Post
Good morning .
Cheers.
NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOO FFS thats not good
Old 09-07-08, 09:04 AM   #6
If the pushrods bent it won't seal, try another one first on the off-chance that it'll work. (unless your replacement one was new, in which case best get the spanners out...)
Old 09-07-08, 10:10 AM   #7
addicted to rage
no u can c the bearing behind the seal is damaged the centre bit that the pushrod slips into is off centre and u can c a ball bearing so id def say its caput
Old 09-07-08, 01:17 PM   #8
drag
Give us a shoult if you want a hand, your not that far away
Old 09-07-08, 01:30 PM   #9
addicted to rage
ah no wouldnt want to trouble u was talkin to the lad in cotters he said there is no bearin behind it im gettin it restricted cause of these stupid new laws so he said he should be able to fix it for me when he is doin the restrctor cheers tho
Old 09-07-08, 01:49 PM   #10
drag
Your clearly having a giraffe there right ?
why in the god name are you getin it restricted ? do you really think a guard walking the street is going to know the diff ? or a guard at a checkpoint.
Push starting an SV 650 K2... trailer_parks SV Talk, Tuning & Tweaking 32 06-08-15 01:35 PM
Rod, Clutch Push Lh peahead Stuff Wanted 4 04-02-08 09:28 AM
Value my (push) Bike 454697819 Idle Banter 14 25-01-08 11:15 AM
Gis a push Davies Idle Banter 8 18-12-07 11:17 AM
Push or Pull?? Stig Bikes - Talk & Issues 30 12-05-05 10:37 AM
