Old 09-07-08, 09:03 PM   #1
Big Daft Lad
Default WTD: Curvy Naked Top Yoke and Bar Rrisers.
Not much else to say.
Mucho cheapness appreciated
Cheers.
Old 10-07-08, 09:43 AM   #2
Ter
Default Re: WTD: Curvy Naked Top Yoke and Bar Rrisers.
Did you want the orginal one?
I've got as a faired top yoke with orginal N risers - the only problem you'd find is mounting te clocks...
Old 10-07-08, 10:15 AM   #3
Big Daft Lad
Good thinking Ter, do the risers bolt though the yoke OK? I bought aftermarket risers but the bolts we too far apart and I couldn't fit them due to the webbing underneath the yoke.
I'm running clip ons with bandit clocks and chrome headlight at the moment and want an easliy convertable bike: high bars to clip ons.
Old 10-07-08, 10:37 AM   #4
Ter
Hey,
I've not attached the two yet but from the looks of it - I expect that they would bolt through the top yoke okay.
So long as you have an alternative method to mount the clocks (if your using any) then these could be fine. I'm not back at the garage until the weekend so I could get you pics then?
Old 10-07-08, 01:03 PM   #5
Ive got a pair of yokes with no risers for the nekkid
Old 10-07-08, 03:15 PM   #6
Ter
You could be in luck BDL...
Old 10-07-08, 06:39 PM   #7
21QUEST
21QUEST's Avatar
Don't forget the OE clipons won't work with 'N' top yoke
Ben
Nemo me impune lacessit.
Old 10-07-08, 09:58 PM   #8
Why not
Old 12-07-08, 10:28 AM   #9
Big Daft Lad
Why not
Presumably due to them bolting onto the underside of the top yoke, but I think that’s more of a locator bolt than anything to do with holding it place. I’d be quite happy riding with the two main bolts on the forks.
Anyway, can anyone confirm if the OE bar risers bolt to the yoke with one bolt or two?
If it's just one I think I’ll just be looking for the risers and use my existing top yoke.
Old 12-07-08, 10:39 AM   #10
21QUEST
21QUEST's Avatar
Why not
It's because of the difference in the design of the pinch bolt area.
Basically on the 'N' top yoke, that section sticks out enough that the OE clipons can't be rotated into normal/correct position.
Ben
Naked Curvy Bottom yoke and Curvy speedo drive 21QUEST Stuff Wanted 6 29-01-09 09:36 AM
Naked Top yoke maviczap Stuff Wanted 2 03-01-09 06:50 PM
K3 650 naked Top yoke airbrush_assasin Stuff Wanted 3 07-09-08 09:27 PM
Curvy front wheel, naked yokes, SRAD bottom yoke yorkie_chris Stuff Wanted 1 29-05-08 09:46 AM
Top yoke for naked curvy gc350 Stuff Wanted 3 28-08-06 12:23 AM
