Old 21-07-08, 07:57 AM   #1
Al_Sweetman
Default Oxford indicator replacement bulbs?
Hi guys,
One of my bulbs has just blown in my Oxford indicator, and I've been trying to get a replacement, but bugger me if I can!
The writing on the bulb reads:
Michiba 12V 21W (pretty obvious)
E13 2D3.
I assume the "E13 2D3" is the 'fitting'/size style, but I can't find any bulbs anywhere that seem to have these numbers?!
Anyone had any experience, or can I just get a normal 12V 21W bulb that looks like it'll fit?
Cheers,
Al.
Old 21-07-08, 12:54 PM   #2
Mogs
Default Re: Oxford indicator replacement bulbs?!
Ring Oxford they're usually very helpful.
Old 21-07-08, 03:10 PM   #3
embee
embee's Avatar
Might get a clue as to type here
Old 21-07-08, 03:58 PM   #4
Al_Sweetman
Phoned Oxford - "you can get a replacement bulb at any one of our registered stockists"....
Grr.
Can find no head or tail of these bulbs anywhere!
Never mind.
Old 21-07-08, 05:26 PM   #5
Dangerous Dave
Are they not the common bayonet type 12v 21w indicator bulbs you can get at any car shop?
Old 21-07-08, 08:10 PM   #6
Al_Sweetman
Bayonette yes, but they're straight (similar to festoon bulbs) as opposed to bulge... And they have offset securing pins.
Popped to halfords and examined all their range (OSRAM, Bosch, own brand) all to no avail.
Guess I'll have to bite the bullet with the Oxford ones!
Old 21-07-08, 11:14 PM   #7
embee
embee's Avatar
'twould appear the E13 2D3 is the certification code not the fitting style. E13 apparently does not assure the same quality standards as the others, according to Phillips anyway.
Could it be a H21W you're after, as shown in this pdf . Is it 9mm diameter?
Old 21-07-08, 11:49 PM   #8
I tried to find some a while back and failed. But you'll probably find that all the shine will fall off the reflector and the plastic will go brittle soon anyway, with mini indicators it's best to just think of them as disposable I think.
Old 22-07-08, 08:35 AM   #9
Al_Sweetman
That looks like the badger!
Thanks embee!!!
Old 22-07-08, 11:45 AM   #10
Dangerous Dave
Try somewhere like Motorsave or any other small auto shop, they are readily available!
Indicator Bulbs, help! injury_ian Bikes - Talk & Issues 3 29-03-07 08:40 PM
14v replacement bulbs? Tin Man SV Talk, Tuning & Tweaking 8 11-09-06 08:49 PM
led indicator bulbs ophic SV Talk, Tuning & Tweaking 1 09-03-05 08:50 PM
LED Indicator bulbs the oaf SV Talk, Tuning & Tweaking 8 06-12-04 10:08 PM
LED Indicator Bulbs snoopy SV Talk, Tuning & Tweaking 8 28-10-04 02:21 PM
