I just had a new rear tyre fitted, and at the same time the mechanic noticed I was almost out on my rear pads. So he prised apart the pistons, removed the pads and stuck in some new Bendix (?) ones witha load of coppergrease. When the wheel was back on, he spun in and there was a faint metal on metal sound on the odd turn of the wheel, like a chef sharpening a knife. Wheel turned ok though. So I rode home. Now I have ridden to work, normal commute, using front brakes to do the slowing, just dragging the odd back brake round slow roundabouts and parking etc, and the front discs are lukewarm as you'd expect, but the rear is very hot. Like you can tap it but not hold it hot. There is also a rainbow discolouration of the pads, like when you heat metal with a blow torch. This would suggest to me that the brakes were binding, but when I have it up on my paddock stand, the wheel spins very well. Better than my front did before I cleaned the calipers, it would hardly turn if mounted wrong. So my questions are these:
1) is it normal for new brake pads to go all rainbow colour where they are touching the disc? 2) why is my rear disc so hot if the wheel seems to spin fine?? 3) is it damaging i.e. going to warp my disc or set my ar$e on fire?? |
Hi Nick, I would say the pads are binding except that don't appear to be when it's up on the stand. Maybe they've cooled down and withdrawn slightly by then.
I'd take out the pads and pump the piston out a bit and clean them up. Damage may already be done to the seals though. Sometimes the dust seals get jammed too. Could definately warp your disc IMO. ![]() |
Captain Awesome
could the disc be bent? when he took the wheel off did he lean it on the disc side?
if it's bent it'll rub against the pads at certain points of the revolutioin, and make that knife sharpening noise try gently using it, if the pedal feels like it's pulsing it could be that perhaps?
Official "Dumbass of the Year" 2011 (•_•) ( •_•)>⌐■-■ (⌐■_■) Deal with it... |
#4 | |
Didn't feel noticably juddery, and now the metal scraping noise is gone, it was just the pads bedding in. Basically you can see the pads working with the lever, they break well, wheel spins fine, everything looks good, just it gets mega hot
Could your foot have been resting on the brake lever by mistake?
6.67300 × 10-11 m3 kg-1 s-2 |
Captain Awesome
it wouldn't feel like a judder, the pedal would pulse slightly, tbh you may well not notice it through a boot. i'd be tempted to fire it up on the paddock stand, bung it in first and let the wheel spin* and then lightly apply the rear brake by hand, as you gently increase the pressure you may or may not feel the pedal resistance changing, but as it's not making the knife sharpening noise i'd be inclined to think it was the pads settling down
*keep pets / kids / loose clothes / treasured anatomical bits away from the moving chain...
#8 | |
#9 |
#10 | |
rear brake disc pointy | kcowgergmm | SV Talk, Tuning & Tweaking | 1 | 17-11-08 07:54 AM |
Rear Brake Disc For A Curvy | 21QUEST | For Sale - SV's and SV related items | 0 | 17-08-08 04:19 PM |
Rear brake disc for curvy | andyb | For Sale - SV's and SV related items | 0 | 27-04-08 06:02 PM |
Curvy Rear Brake Disc: | MrMessy | SV Talk, Tuning & Tweaking | 6 | 26-11-07 06:56 PM |
Smaller rear brake disc and caliper.... anyone? | Vtwinlover | SV Talk, Tuning & Tweaking | 2 | 17-07-05 07:28 PM |
