Old 29-07-08, 12:35 PM   #1
manicmonkey
Default Chain wearing through swingarm.
Hello, I'm new to biking and am wondering if its normal for the chain to rest on the swingarm when the engine is stopped? It also looks like its been wearing little grooves in it...
I'm sure someone will ask what the free play is, so ill go check that now...
Old 29-07-08, 12:40 PM   #2
manicmonkey
Default Re: Chain wearing through swingarm...
ok, on further investigation... it seems to be wearing through some manky slab of rubber... and the play is about 35mm on the sidestand which seems about right
Old 29-07-08, 12:42 PM   #3
Yeah, that's what the manky slab of rubber's there for.
Old 29-07-08, 12:42 PM   #4
Luckypants
Luckypants's Avatar
The manky piece of rubber is the chain slider That is what it is there for and it is doing it's job of protecting the swing arm. It's a wearing part and needs to be replaced periodically (I Think).
HTH
Old 29-07-08, 01:12 PM   #5
Stig
HTH
Your right it is a sacrificial part. But the chances of it wearing out so much that you need to replace it are almost non existent. With the chain on under tension whilst riding, it barely touches the rubber slider.
Old 29-07-08, 01:14 PM   #6
dirtsk8
You could make a home made one.
Old 29-07-08, 01:23 PM   #7
Grinch
Is it slack....
No...
Then you should be fine...
Old 31-07-08, 06:53 PM   #8
manicmonkey
Cheers for your advice guys, I was a bit worried, but ill put it out of my mind now!
Chain Change - Remove Swingarm? Coder SV Talk, Tuning & Tweaking 12 16-04-09 11:29 AM
Tyres wearing out suddenly Ceri JC SV Talk, Tuning & Tweaking 21 29-08-07 09:31 PM
Wearing a dress Law Idle Banter 82 14-12-06 02:44 PM
Chain Touching Swingarm Full Throttle SV Talk, Tuning & Tweaking 2 08-03-06 05:49 PM
New Brake Discs - wearing in Balky001 SV Talk, Tuning & Tweaking 4 01-05-05 08:23 PM
