Old 20-08-08, 07:31 PM   #1
nik_nunez
Default clunking noise under braking
under slightly heavy braking the front end seems to make a clunking noise and feels a bit off - mainly occurs when gearing down and using the front brake
is this normal or is something up? its going in for its first service on friday so any ideas would be welcome
Old 20-08-08, 07:38 PM   #2
Nemo
Default Re: clunking noise under braking
Hhhhhmmmmm mine does the same i think its something to do with the forks any ideas anybody?
Old 20-08-08, 08:35 PM   #3
Spikenipple
Spikenipple's Avatar
Sounds like either the head bearings being loose or your wheel bearings are shot. Make sure you mention it when you get it serviced!
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 21-08-08, 12:08 PM   #4
Jase22
They all do it.
Old 21-08-08, 12:17 PM   #5
sinbad
Originally Posted by Jase22 View Post
They all do it.
When you hit a hefty pothole perhaps, but not under brakes, ever. (In my experience. I'd be concerned if it did).
Old 21-08-08, 02:05 PM   #6
niccollotto
my [pointy does it and so did my previous curvy, Had steve jordan look at both and he reckons they all do it, his missus who races mini-twins also reckons they all do it, had ohlins springs fitted to mine with stiffer oil and it still does it, it even knocks slightly when depressing the forks at stand-still, if the jordans dont know what it is i guess nobody does.... have to say htough that its never affected the handling or braking of mine on road or track, someone told me its the mudguard flexing, but cant be bothered to take it off to prove it !!
p.s get the ohlins fork mod done (about £100 if you take it in) absolutely transforms it !
Old 21-08-08, 02:18 PM   #7
jambo
jambo's Avatar
They all do it.
There are several things that can have similar sounding symptoms over the internet. Check your head races, wheel bearings and that the brake disks are not moving on their mounts. There does seem to be a harmless clunk from the SV forks, but it's worth checking that this is what you're hearing.
Jambo
Old 21-08-08, 08:09 PM   #8
Nemo
good point that, mine is an 05 and has always done it. It doesnt affect the bikes handling in anyway brake discs are ok head bearings are fine and it is just when i go over pot holes or something alike.
Old 21-08-08, 08:36 PM   #9
SV-net
I find that with the floating discs on these bikes they can chatter when cold, also if your front pads are quite worn the calipers can seem like they are loose. Remember the discs should be able to move a small amount on their mounts.
As for the head bearings I will check mine tomorrow, just want to be sure my clonking is not something serious.
Good comments on this thread, cheers.
Old 21-08-08, 09:41 PM   #10
BILLY
Mine did it and it had USD srad front end fitted!!
It still makes that clunking fork noise. Tony_BLY SV Talk, Tuning & Tweaking 29 01-03-09 10:48 AM
Clunking noise on GSXR750 rubberduckofdeath Bikes - Talk & Issues 8 06-06-08 05:19 PM
clunking chain noise steveg Bikes - Talk & Issues 4 23-03-08 10:39 PM
clunking starter? toyotafj40s SV Talk, Tuning & Tweaking 7 23-08-06 10:50 PM
chain is clunking rednorvs SV Talk, Tuning & Tweaking 6 13-11-05 07:08 PM
