Old 21-08-08, 01:25 PM   #1
Xan173
Default Mountain bike - what's it worth?
I've not made much use of my mountain bike lately and wondered if any of you had any idea what it might be worth and where I might post it up for sale?
2004 Specialized Stumpjumper FSR Expert
This was the orginal spec...
Frame: FSR technology, M4 Manipulated Alloy frame with Transform monocoque TT, sealed cartridge bearings, disc compatible, 120mm travel, replaceable derailleur hanger, two sets of water bottle bosses REAR SHOCK Fox Float Septune. Custom on-the-fly seven position adjustable ProPedal pedal assisting damping. External rebound adjust. 7.5x1.75”
Forks: Fox Talas RL, 95-130mm travel, rebound adjust, compression adjust with lock-out, alloy steerer
Rear Derailleur: Shimano M-952 XTR, long cage, standard spring
Front Derailleur: Shimano M-570 LX, 34.9 clamp, bottom pull
Shifters: Shimano M-570 LX
Chainset: Custom Shimano Hollowtech, Octalink XT Spline 44Ax32Ax22S, 4 bolt 104/64mm pattern, Steel chainring bolts
Bottom Bracket: Shimano ES-30 Octalink spline, 68mm shell, 118mm spindle. 50mm chainline.
Chain: Shimano HG-73
Freewheel: Shimano HG-50 LX, 9-speed, 11x34t
Headset: 1 1/8” Threadless, 3x sealed, black alloy cups, cartridge bearings, ultralight alloy top cap and bolt
Stem: 3D forged CNC machined, 4 bolt, 31.8mm OS clamp, 8 degree rise
Handlebars: Specialized XC Low Rise 31.8mm OS bar, 2014 butted alloy, 6 degree upsweep, 8 degree backsweep, 640mm width
Front Brake: Shimano M-765 XT hyd disc, metallic pads, 6” XT Rotor
Rear Brake: Shimano M-765 XT hyd disc, metallic pads, 6” XT Rotor
Brake Levers: Shimano M-765 XT hydraulic disc with integrated shifters
Rims: Mavic X317 disc, 26”, black, eyelets
Front Hub: Specialized Stout Disc, 32 hole
Rear Hub: Shimano M-525 Disc, 32 hole, loose ball bearings, alloy Q/R
Spokes: DT Swiss Competition, 1.8mm, SS, black, alloy nipples, L258/R261mm front, L259/R258mm rear
Tyres: Specialized Adrenaline Pro 2.0, aramid bead, 120tpi
Saddle: Specialized BG technology, hollow Cr-Mo rails, dual density base
Seatpost: 2014 butted Alloy, black, 30.9 x 350/400mm
Pedals: Shimano 520 SPD
Grips: Specialized MTB grip, black, double density Kraton
Miscellaneous: Chain stay/seat stay protector, derailleur protector, seatpost water bottle mount, reflectors, owners manual
All standard apart from 2" cut off the seatpost to allow it to be lowered right out of the way for very steep decents. DMR sealed bearing flats.
Old 21-08-08, 01:27 PM   #2
Scoobs
Default Re: Mountain bike - what's it worth?
Less than 1/2 what you paid for it. Mountain bikes are like computers. They are old hat within a year.
Old 21-08-08, 01:55 PM   #3
gettin2dizzy
And the cycle to work scheme means you can get a 43% discount on a new one I'm afraid.
Old 21-08-08, 02:56 PM   #4
Viney
So in other words, i'll give you a tenner for it
Old 21-08-08, 03:23 PM   #5
BernardBikerchick
lots and lots and lots !
Old 21-08-08, 05:50 PM   #6
phil24_7
I'll up the bidding to £15!
You got any pics??
Old 21-08-08, 08:23 PM   #7
dirtsk8
Stick it on eBay with a reserve of £600 and watch it go for round about that or thereabout.
Old 21-08-08, 09:47 PM   #8
Xan173
Tee hee!
Old 22-08-08, 08:40 AM   #9
sibbo
hi you could try to move it on bikemagic.com vist the site and see what they going for then you could buy my marin mount vision and still have enough for some ships hahahahahahahaha
Old 22-08-08, 08:41 AM   #10
sibbo
oops i meant chips
Recommend me a mountain bike Paul the 6th Idle Banter 20 21-05-09 02:48 PM
Mountain Bike Touring gettin2dizzy Idle Banter 10 28-07-08 07:40 PM
Mountain Bike advice please.. StreetHawk Idle Banter 18 01-05-08 05:27 PM
Mountain Bike/Motorbike Demonz Bikes - Talk & Issues 12 05-12-07 02:10 PM
For Sale: Gents Mountain bike KayDee Idle Banter 0 18-05-06 02:41 PM
